Old 09-09-2019, 09:55 PM
RichrdC RichrdC is offline
Default Plug-ins Not Recognized On /a New Track
Hello to the community.. I appreciate the insights of you all.! So, I have the MBox 3rd generation going directly into a Lenovo laptop. I have ProTools 18.4...Happy with that.. I can arm a new track and record. Problem is that I can't seem to get a plug-in to be recognized when put on that track. Any plugin.. I'm perplexed? It's like the MBox is just a way to hear my guitar through the headphones even if I don't have Pro Tools open.. The physical setup is simple enough, so I must have a setting in Pro Tools wrong..or maybe the Mbox is set up wrong?? I appreciate any insight into my next step?? Thank you all, RichrdC
Old 09-10-2019, 09:04 AM
Default Re: Plug-ins Not Recognized On /a New Track
Maybe I should ask, why a plug-in might not be recognized?
Old 09-10-2019, 09:44 AM
Ben Jenssen's Avatar
You need to explain what happens. Does it not show up in plugins menu? Can you instantiate it but not hear its effect? If it's the latter, have you checked if what you're hearing is the direct input signal on the mbox and not PT main out?
Old 09-10-2019, 10:08 AM
All the plugs show up in the drop downs.. I can click on one, say Reverb and it'll show up on the insert, but it has no effect. I can strum the guitar through my MBox 3rd generation, and there's no change in the sound of the guitar.
Old 09-10-2019, 10:16 AM
I quote myself:
...have you checked if what you're hearing is the direct input signal on the mbox and not PT main out?
Old 09-10-2019, 10:19 AM
JFreak JFreak is online now
Does your output mute when you drop the output slider to bottom? If it doesn't it is clear that you are not monitoring your PT output.
Old 09-12-2019, 08:22 AM
I think you're correct JFreak..I mean, I can have my guitar & headphones plugged into my Mbox3 and I can hear the guitar even without having ProTools opened up.
I spent some time yesterday trying to really flesh out the issue. I'm just getting back into having the studio up and running so I've sort of become a newbie again.. I hate when life gets in the way!
So, I have an established session on which are many plug-ins.. I can change patches to any of them, and I can hear the changes through my headphones when I play the session.
Now, I record enable a track, any track, and I can no longer hear any patch changes to the plug-in on the record enabled track. I can record to the enabled track. I can see the signal in the meter. It will record.
I think I need a link to setting up the links. It seems the plug-in path isn't right.
I've gone to the I/O settings and hit the default button.
I did the same in the Settings of the Mbox3.
I have a Lenovo lap top that has 2 USB2 connections and 1 USB3, which I haven't utilized. I've got the Mbox3 connected directly to the computer, and everything else on a hub to the other USB2.
I use a ICON Qcon Pro X control surface.
I've searched quite a bit for a video that would lend some insight about Protools 18.4 software set ups.. Maybe that's what I need most. I just haven't found it yet.
All worked well till I had to break down the rig, which stayed broken down for about a year and a half.. So now, I can't wait to have it working once again..
Thank you for reading this..
Old 09-12-2019, 08:38 AM
It's very easy. The Mbox can output the PT main outs. And it can output any signal coming in thru mic/inst inputs directly. Or a mix of the two. This is very common on interfaces. Usually you can choose how much you want from each on the hardware or in the Mbox software. Check the Mbox manual.
Old 09-12-2019, 09:01 AM
The Weed's Avatar
The Weed The Weed is offline
Is LLM on? If it is, IIRC, any plug-in on a Record Enabled Track is turned off.
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 09-13-2019, 11:05 AM
Are you speaking of Low Latency Monitoring? I'm pretty sure I've got that off, but considering I've been all over the place looking at different options to set, I'll have to check again..
AAX Plug-Ins Not Recognized vorker Pro Tools 11 12 09-02-2013 11:36 AM
Fast Track Pro not recognized lDuff FireWire and USB Audio Interfaces (Win) 2 08-24-2013 10:03 AM
Musiclab plug-ins are not recognized kaet macOS 1 09-14-2011 06:44 AM
how to get third party plug in recognized? jonQpublic Virtual Instruments 4 03-31-2010 09:49 PM
Drivers/Plug ins not being recognized AudioArtCafe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-06-2005 04:39 PM
