Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | S3
  #21
Old 08-14-2019, 01:00 AM
themissingcow themissingcow is offline
Default Re: S3 + Mackie Control or HUI
Originally Posted by themissingcow View Post
I tried the 3.6.1 + 18.3 trick and the ports re-appear, but installing 19.7 over the top makes them disappear again (even if I don't un-install).
I just tried an experiment, and copied the EuphonixMIDI.plugin from the 18.3 install over the top of the one from 19.7 and now the ports show up. So this might be a work-around for those who need the update + MackieControl emulation. What I did was:
1. Install 3.6.1 then 18.3
2. Copy /Library/Audio/MIDI Drivers/EuphonixMIDI.plugin somewhere safe
3. Install 19.7
4. Copy EuphonixMIDI.plugin over the newly installed one
5. Restart
  #22
Old 08-21-2019, 07:49 AM
morten@mortenhaugen.com morten@mortenhaugen.com is offline
I have Artist Mix up and running in Mackie Control mode with Reaper. The basic functions are working ok (faders, ON, Solo etc.), but the Solo buttons do not light up when pressed (as opposed to the On buttons which light when supposed to).
What could cause this, and how to fix?
  #23
Old 08-21-2019, 10:18 PM
EddieJones's Avatar
This would be on Reapers end...maybe not even implemented? Out of interest what OS are you one and what version of EUCON ?
  #24
Old 08-22-2019, 01:07 AM
Windows 10 64-bit, EUCON 19.5.1.
I see there's a new EUCON version out (19.7), will try that.
  #25
Old 08-22-2019, 10:51 AM
EddieJones's Avatar
Ah OK..Yes Windows works fine for Mackie Control...Its OSX that has the issues.
  #26
Old 09-01-2019, 04:07 AM
On the Avid Artist Mix control I can hold a shift button and touch a fader to reset it to default position (0 dB), similar to double clicking the fader with the mouse directly in Reaper. But the Avid Artist Mix sets the level to +2.94 dB instead of 0 dB.
Any ideas how to fix that?
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control lberrios1962 Pro Tools 10 18 05-26-2012 01:51 AM
Digi 003 Control Surface Mackie Control Mode ctmusicman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-23-2008 08:23 PM
Mackie Control Universal or Tascam 1082 for control surface? anders Pro Tools TDM Systems (Mac) 5 05-28-2007 07:12 AM
Can the Mackie Control extender work w/o Mackie Control? fingerz88d 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-03-2003 09:52 AM
a note from Mackie about the Mackie control remote Pro Tools TDM Systems (Mac) 100 11-02-2002 01:25 AM
