Old 05-21-2019, 10:37 AM
haha10024 haha10024 is offline
Default S3 faders 1-8 not sending/receiving data
I have an S3 that has been RMA'd once. I've tried all iterations of firmware with no change in behavior. First 8 faders don't respond at all when synced with EUCON. Faders 9-16 are good.
I have ruled out the faders as the issue. During boot up/firmware update sometimes they will move sporadically. Also swapped #1 and #10 and no change.
Anybody with knowledge of the circuitry possibly have an explanation? I have the board opened up right now and I can see the green LEDs (rear side) near the faders are not lit up for the #1-8 half. They come on briefly when power is cycled.
Thanks for any insight you may have! Let me know if pictures would help.
Old 05-22-2019, 08:55 AM
EddieJones's Avatar
Default Re: S3 faders 1-8 not sending/receiving data
Have you tried using test mode ? http://avid.force.com/pkb/articles/e...lity-Test-Mode
Old 05-22-2019, 10:50 AM
Originally Posted by EddieJones View Post
Thanks Eddie. Yes, 1-8 still unresponsive during test mode. About 99% sure this is an electrical fault somewhere in the circuitry.
Eleven Rack Stopped Receiving MIDI data? Vultage Eleven Rack 2 03-17-2016 10:32 AM
Not receiving much signal from audio on faders remusjacobs macOS 0 02-17-2012 07:34 AM
New problem with sending and receiving Top Jimmy Aspera DigiDelivery 0 06-29-2007 01:04 PM
MOTU Fastlane w/Mbox, not receiving MIDI data.HELP drg73 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-14-2003 02:30 PM
Midi not receiving data raj 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-12-2001 06:03 AM
