Old 02-09-2010, 08:04 PM
RELAV RELAV is offline
Default No sound from Digirack 003 Headphones and Monitors!
Help! Suddenly out of the blue without touching or changing anything I am getting no sound from the headphone outputs or the monitors. I get sound directly from line 1 and 2 outputs in the back, but nothing else is working! What happened?!? Is it possible something blew? I've only had this thing for a couple weeks...
Protools opens up fine, and it shows a signal in when I hook up a mic to the rack. The only thing not working are the headphone and monitor outputs.
Please, PLEASE, desperately looking for answers and finding none.
Old 02-10-2010, 09:34 AM
Default Re: No sound from Digirack 003 Headphones and Monitors!
Recheck your IO setup. Then recheck the outputs on your tracks.
Old 02-10-2010, 09:42 AM
yeah, checked all that to no avail. finally got through to tech support this morning. Turns out it was as simple as someone, unbeknownst to me, pushing the "Aux In" and "Alt CR" buttons. Not familiar enough with my system yet...
Old 01-05-2011, 01:55 PM
kmelton@resonline.org kmelton@resonline.org is offline
I'm having the same problem with 002 Rack. When I first installed the crossgrade, I opened an existing session and it played just fine! Then after I installed the Instrument Expansion nothing! Very frustrating! I hear it in the computer speaker and no where else!
Help!
Old 01-05-2011, 05:37 PM
danander11 danander11 is offline
Help!
You are not having the same issue. You have your output set wrong for your sound.. (my guess at any rate).
Go to SETUP on the menu bar and make sure that your playback engine is set to your 002 and not to your internal speakers. That will probably fix it for you.
Here I am,
after time not long...
and thankful for the break,
What I found when I got there,
was that I couldn't stay away!
Hobo Shave!
monitors vs. headphones teketuco General Discussion 14 08-01-2015 07:49 AM
headphones VS Monitors christophersad Eleven Rack 4 03-14-2013 12:16 AM
Mbox 2 Mini Sound coming through both Monitors and headphones jt1432 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-12-2011 11:06 PM
No sound out of my monitors or headphones Baumtracks macOS 12 01-11-2011 07:03 PM
monitors and headphones will-i-am 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-07-2004 05:24 PM
