Old 08-27-2001, 10:13 AM
Ozzie Ozzie is offline
Default Midi Beat Clock
When trying to sync a MC500 to Pro Tools, through Midi Beat Clock, the MC500 does no sync consistently the same and drifts ever so slightly. As Pro Tools runs the midi clock surely it should run the MC500 the same each time as any drift in Pro Tools should alter the output of it's Midi clock keeping the MC500, effectively, running the same. Any ideas?
Thanks
Old 08-27-2001, 10:25 AM
cane cane is offline
Default Re: Midi Beat Clock
hi.
i run my mpc3000 with midi beat clock sync to ptle as the master with no drift at all.
Have you checked that the mc500 is definetly got ext. sync turned on & also that it can receive midi beat clock.
Sorry to ask the obivious.
I have an AMT8 which i use to sync it through, maybe try another midi interface see if it has the same problem.
From what i've read on this forum the midi on the 001 is still not 100%.
Anyhow good luck. [img]images/icons/wink.gif[/img]
Old 08-27-2001, 11:59 AM
mc500 is on midi sync. I'm using the 001 midi in and outs.
Old 08-31-2001, 09:31 AM
Thanks Cane for your input. Anyone else out there with any experience of midi beat clock and mc500?
Thanks
MIDI Beat Clock? guitarless Eleven Rack 3 10-24-2010 04:39 PM
Pro Tools Slaved by Midi Time Code or Midi Beat Clock DarylBham MIDI 5 06-14-2009 02:55 PM
MIDI BEAT CLOCK STILL Bad on PT 7.1.1 alx002 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 29 12-10-2006 12:59 PM
Triton...is MIDI Clock difrnt than MIDI Beat Clock BookSix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-12-2006 01:24 AM
Midi beat clock & 6.0 big_giz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-09-2003 12:15 AM
