9073 errors - sandra report included.
Haven't ran a session from my external drive in a while, figured might as well try today just for a quick practice mixing session....
well of course, I get the dreaded 9073 errors during playback. No plugins used, just clean tracks, about 20 give or take. The simple... Mbox2 OS: W7 - 64bit Ram: 4GB Mobo: Abit IP35 (w/ TI firewire chip) External drive: WD MyBook Studio Edition connected via Firewire 400. (has FW400/800/Esata/USB) I've dual formatted the drive into both HFS+ (using MacDrive) and NTFS (50/50 split). Tested session on both partitions, same error. Last time I tried using a session via an external drive was before 8.01 as I usually just copy sessions to my audio drive. Any suggestions? Thanks Sean ----------------------------------- Sandra Report Computer Model : System Manufacter System Product Name Workgroup : WORKGROUP Host Name : sean-PC User : sean Processor Model : Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz Speed : 3.2GHz Cores per Processor : 4 Unit(s) Threads per Core : 1 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 2x 4MB, ECC, Synchronous, ATC, 16-way, 64 byte line size, 2 threads sharing Computer Mainboard : Abit IP35 (Intel P35+ICH9/R) BIOS : Phoenix Technologies, LTD 6.00 PG 02/29/2008 Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 4GB DIMM DDR2 DDR3 Chipset Model : Abit Computer P35/G33/G31 Processor to I/O Controller Front Side Bus Speed : 4x 356MHz (1.42GHz) Total Memory : 4GB DIMM DDR2 DDR3 Memory Bus Speed : 2x 356MHz (712MHz) Memory Module(s) Memory Module : Mushkin 991557 996557 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-24-6-3) Memory Module : Mushkin 991557 996557 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-24-6-3) Video System Video Adapter : NVIDIA GeForce 8800 GT (2x 112 SM4.0 1.55GHz, 2x 512MB DDR3 2x952MHz, PCIe 1.00 x16) Video Adapter : NVIDIA GeForce 8800 GT (2x 112 SM4.0 1.55GHz, 2x 512MB DDR3 2x952MHz, PCIe 1.00 x16) Graphics Processor Adapter : NVIDIA GeForce 8800 GT (495.6MB 2x952MHz) Storage Devices ST31000340AS (1TB, SATA300, 3.5", 7200rpm, NCQ) : 932GB (F:) (H:) WDC WD6400AAKS-75A7B0 (640.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 596GB (D:) WDC WD6400AAKS-75A7B0 (640.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 596GB (C:) WDC WD5000KS-00MNB0 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 466GB (G:) WDC WD20EADS-00R6B0 (2TB, FireWire/1394/SATA300, 3.5", NCQ, 32MB Cache) : 2TB (I:) (J:) SONY DVD-ROM DDU1613 (ATA33, DVD+-R, CD-R, 512kB Cache) : N/A (R:) Optiarc DVD RW AD-7241S (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (S:) ELBY CLONEDRIVE (SCSI, SCSI-2, BD-R, HD-DVD-R, DVD-R, CD-R, 256kB Cache) : N/A (E:) Logical Storage Devices Projects (F:) : 466GB (NTFS) @ ST31000340AS (1TB, SATA300, 3.5", 7200rpm, NCQ) MyDocs (D:) : 596GB (NTFS) @ WDC WD6400AAKS-75A7B0 (640.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) BOOT (C:) : 596GB (NTFS) @ WDC WD6400AAKS-75A7B0 (640.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) Utility (G:) : 466GB (NTFS) @ WDC WD5000KS-00MNB0 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) StudioMAC (I:) : 933GB (HFS+) @ WDC WD20EADS-00R6B0 (2TB, FireWire/1394/SATA300, 3.5", NCQ, 32MB Cache) STUDIO2 (J:) : 930GB (NTFS) @ WDC WD20EADS-00R6B0 (2TB, FireWire/1394/SATA300, 3.5", NCQ, 32MB Cache) SAMPLES (H:) : 466GB (FAT32) @ ST31000340AS (1TB, SATA300, 3.5", 7200rpm, NCQ) Optical Drive (R:) : N/A @ SONY DVD-ROM DDU1613 (ATA33, DVD+-R, CD-R, 512kB Cache) Optical Drive (S:) : N/A @ Optiarc DVD RW AD-7241S (SATA150, DVD+-RW, CD-RW, 2MB Cache) Optical Drive (E:) : N/A @ ELBY CLONEDRIVE (SCSI, SCSI-2, BD-R, HD-DVD-R, DVD-R, CD-R, 256kB Cache) Peripherals LPC Hub Controller 1 : Intel (ICH9) LPC Interface Controller LPC Legacy Controller 1 : Winbond W83627DHG Audio Device : Abit Computer (ICH9) HD Audio Controller Audio Codec : Realtek Semiconductor 888 High Definition Audio Disk Controller : Abit Computer (ICH9) 6 port SATA AHCI Controller Disk Controller : Jmicron JMB368 IDE Controller USB Controller 1 : Abit Computer (ICH9) USB Universal Host Controller USB Controller 2 : Abit Computer (ICH9) USB Universal Host Controller USB Controller 3 : Abit Computer (ICH9) USB Universal Host Controller USB Controller 4 : Abit Computer (ICH9) USB2 Enhanced Host Controller USB Controller 5 : Abit Computer (ICH9) USB Universal Host Controller USB Controller 6 : Abit Computer (ICH9) USB Universal Host Controller USB Controller 7 : Abit Computer (ICH9) USB Universal Host Controller USB Controller 8 : Abit Computer (ICH9) USB2 Enhanced Host Controller FireWire/1394 Controller 1 : Abit Computer TSB43AB22 1394a-2000 OHCI PHY/Link-Layer Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : HP LaserJet 5 (600x600) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Generic Marvell Yukon 88E8056 based Ethernet Controller (Ethernet, 1Gbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7600 Platform Compliance : x64 Windows Experience Index Current System : 5.9 |
Re: 9073 errors - sandra report included.
Interesting...
So many people harp about having Sandra reports and the right hardware... but when someone has that... threads become ghosts towns. Anyways, I found the 'cause' of my symptoms, however I'm unable to fully resolve it. A while back I discovered for whatever reason, in Win7 (not sure if this is only 64bit related or not) but many report that the standard drivers for on board firewire cause slow transfer rates. I've experienced this as well. Low as 15MB/sec or lower, which is slower than if I connected up the same drive via USB. Many have reported re-gaining their firewire transfer speed if they set the driver to 1394 generic "legacy". I performed this as well an my transfer speeds seem to shoot right back up to normal. However, during recent testing... I decided to put the driver back to the standard TI driver and discovered that streaming sessions from my firewire drive worked again. As expected, transfer rates (copy to and from the drive) plummeted though. Putting the legacy driver back though restored the transfer rates, however killed PT session streaming. My TI chip is a TSB43AB22, however, Abit is no longer making drivers/bios/etc due to leaving the motherboard business. Also remember, I'm using an Mbox2, which is USB, so that would not be causing the issue with the gernic driver either. If anyone has any idea, please feel free to let me know. |
G-series chipsets if I'm not mistaken indicate integrated graphics, which cause conflicts.
Did you (even if you're not using it) disable on-board graphics in your BIOS? |
************ Also I have one of the same drives (MyBook Studio) and PT hated it. I used it only for backups. Then re-formatted to NTFS... better but not perfect. Something about the logic in these drives doesn't agree. None of my other F/W drives have this issue.
My chipset is a P35. No onboard graphics.
Updated bios. Same issue persists. Guess my only resolution is to replace the mobo or keep flip flopping the driver around. |
If you replace the mobo with one that DOESN'T have a p35, you'll have to re-load Windows.
Yep, I'm aware.
Considering getting a PCI/PCIe firewire card instead. Anyone have any they recommend? |
3 critical errors I'm regularly receiving (Sandra Report Included) | TheJamsh | Windows | 2 | 12-11-2011 10:12 AM |
Pt9.0.5 Help Please (Sandra Report Included) | msuk | Windows | 2 | 09-25-2011 08:48 AM |
6085 and 6088 Errors - Just Started - Sandra Report Included | JCWarrior | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 11-03-2010 02:13 AM |
Three problems since 8.0.4 - Sandra report included. | David Sabine | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 10-22-2010 10:44 AM |
Need Help Debugging PC - SANDRA Report Included | EarBud | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 08-23-2010 07:09 PM |
