Old 09-19-2009, 10:14 AM
Arya44 Arya44 is offline
Default 003 Surface auto write/latch/touch buttons not working
Hi there,
Is there anyone with this problem that the 003 auto buttons other than suspend is not working? Or there is a lack of knowledge on my behalf?
I can change the read to write, etc with mouse but when I press the button on the 003, it doesn't do anything. The only button that works in that area is "suspend".
I'm running PT8 G5 Leopard 10.5.8 with 003/CP Toolkit
Thanks.
Old 09-19-2009, 10:35 AM
Default Re: 003 Surface auto write/latch/touch buttons not working
Sorted out. I just rushed and missed the procedure: Hold down the auto and select the track. I was doing it the other way around.
Sorry
Using the trimmer after WRITE, TOUCH or LATCH - wonky Farmer Dave macOS 1 05-30-2012 04:44 PM
Behringer BCF2000, read, write, touch buttons JTA Sounds Pro Tools M-Powered (Win) 0 09-20-2010 08:23 AM
Autowrite/touch/latch not working on mix window ilianarose 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-08-2007 06:17 PM
Write defaults to Latch instead of Touch in LE6.9 Headmxr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-20-2006 12:27 AM
6.9 Default to Auto Latch after Write Automation.. a2zproductions 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 02-20-2006 12:10 AM
