Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
Old 09-20-2018, 01:25 AM
Protone Protone is offline
Default Offline bounce takes forever to start
I have had this issue for years, from PT10 at least, and with many osx versions, but I think it is gone worse now with Protools Ultimate.
When I have a large session and I bounce it, nothing happens for a minute or so. Then the progress bar starts going, and after it's done there is another long pause (20-30s) before Protools is responsive again.
Is this normal? Is the offline bounce really this bad by design? These pauses are there even with light sessions, but they are shorter.
I also use Logic Pro, and no matter how heavy the session is, the bounce starts immediately.
My system: OSX 10.12.6, Mac Pro 5.1, Protools HD Native PCI.
Old 09-20-2018, 02:47 AM
Farhoof's Avatar
Farhoof Farhoof is offline
Default Re: Offline bounce takes forever to start
Are you using the rewire plugin to monitor something like soundminer? If so, remove it (restart may be required).
Old 09-20-2018, 06:04 AM
Southsidemusic's Avatar
Good advice, also what plugins are on the master as i know some izotope plugins and other heavy use ones can start issues but haven’t seen this in a long time. Here it starts asap no matter what session size. Shouldn’t take that long or behave line that.
Best Regards
Christopher
South Side Music Group
WEBHOME
Old 09-20-2018, 06:45 AM
amagras amagras is offline
I could be wrong but I think Pro Tools need some time after exporting to create the final stereo file, probably more justified if you are working with dual mono stereo files to start with. If you are using plugins with higher levels of oversampling this will definitely increase the export times, sometimes to crazy lengths. The solution for me is to freeze the tracks where I'm using values > x8 as soon as I'm done with them.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 09-20-2018, 12:10 PM
originalscottyg originalscottyg is online now
If you are using HDX, Pro Tools takes some time to recreate the mixer and the DSP plugins natively before it can begin bouncing, and again to instantiate all those things on the cards before returning control to PT.
EDIT: It looks like you are using HD Native, so I am not sure this would apply. Certain plugins can make offline bounce take a long time, though. I believe anything Soundtoys is one, and there are probably others.
Scott Gatteño
Yessian
Old 09-21-2018, 02:12 PM
its2loud its2loud is offline
Amazing! Thank you for this insight. I had posted the same exact question a few days ago and got a rather snarky response about not providing enough information about my system. Im glad to find a solution to a much hated issue.
I deactivated the Soundminer Engine plugin (SM Engine 4.0) in the session and the bounce started right away. No wait time and it was a much faster bounce overall. 9.1x compared to 1.2x previously. Also, there was no hangup when it was done bouncing.
Originally, I had only changed all the plugins to Native but this didnt change anything. So I went back to a DSP/Native combo and just removed the soundminer plug and all was well.
A full Pro Tools restart was required after deactivating the SM plugin. Far less time than waiting for the bounce to start on a long project.
Again, thanking for saving hours of watching the Mac beach ball.
Old 09-23-2018, 08:02 AM
Thanks for all the replies!
I am using rewire (sound miner), AND izotope plugins on the master. I'll try removing them first thing tomorrow and see if it makes any difference.
Old 02-29-2020, 11:46 AM
speetman speetman is offline
Thank you Farhoof! This was a mystery to me also. I was using rewire with the Wave Tune plugin. Once I recorded the tuned vocal I removed Rewire and it fixed the problem. Much appreciated.
PT 10 takes forever to start up DJYoutubeDJ Pro Tools 10 3 06-28-2013 01:39 PM
Pro Tools 11 takes forever to start? hollywoodbeats Pro Tools 11 6 06-25-2013 05:49 AM
PT9 takes forever to start opening Ryan Young macOS 2 12-27-2010 03:51 PM
Pro Tools takes forever to start up livstone Pro Tools TDM Systems (Mac) 7 11-06-2004 08:21 AM
001 recording start takes forever jtrolka 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 05-29-2003 12:57 AM
