Very Odd Sync issue, HD 11.3.2 - Bounces Arrive early?!
Hello everyone,
First off, my system is as follows: imac late 2013 - Intel i5 3.2Ghz, 32gb ram, NVIDIA GeForce GT 755m 1gb vram OS X 10.10.5 Pro tools HD 11.3.2. Avid HD Omni interface. Magma thunderbolt Chassis If I left anything out please let me know! I am working in promos, and we do primarily 20 and 30 second spots. The editors here are not into using 2-pops and tail pops, so i can't even use that system to ensure a sync which really stinks for me because whenever I bounce a track, the bounce is about a frame early. It's the correct length of time, and it's in the correct place on the timeline, but all of the waveform is ahead by one frame. Low latency monitoring is off. Delay compensation is on. I removed the only two plugins in this particular spot (izotope insight and ozone 7 vintage limiter) and the problem remains. I created a new test session and made 4 mono and 4 stereo tracks, each with a pop exactly 5 seconds apart. I then set up my busses and routing as I would in a promo session and did a test bounce. No issue. Any idea what could be causing this? I honestly don't know how to troubleshoot this, and I am puzzled as to how a bounce could arrive early in the timeline. I attached a screenshot: the blue tracks are what's in my mix/timeline. The red, purple and green tracks are my bounces. The red is the first bounce which is where the problem started. The purple track is a bounce with no plugins. The green track is a real-time bounce with no plugins. I hope this is some little setting I'm overlooking. As you can see, this mix is so simple that I have it all routed to a single mix bus. Obviously this could be circumvented by using 2-pops and tail-pops and delivering that way, but the editors will have none of that. Any help will be eternally appreciated. Thanks! EDIT: here is a link to better resolution image: https://anonimage.net/image/IFQXP54thg EDIT #2: here is a screenshot of more bounces: https://anonimage.net/image/SoToES4Lgc ---Each time I bounced the mix, i solo'd it and bounced it again, and each time, it (magically?) gets earlier in the timeline, losing time at the front and adding time at the back. Last edited by IDONTLIKEUSERNAMES; 09-08-2017 at 10:56 AM. Reason: Picture was potato'd - provided better image |
Re: Very Odd Sync issue, HD 11.3.2 - Bounces Arrive early?!
Did you check the manual compensation may be there is a negative one on the aux...
In the mix window cmd+click to read your delays... Sent from my SM-G900H using Tapatalk |
Does it happen when doing an offline bounce and realtime or only in 1 situation? I print internally so don't deal with bounces much but was curious if might be a buffer or disk issue.
I can't see your routing in your screenshots. I've had this with bus-bussing stem and simultaneous full mix recording structures. This doesn't seem to be working so I get my stems printed first and afterwards combine them via offline bounce to get the full mix.
Checked that, no negative values anywhere.
Nobody is spending $2700 but maximum $1500 or $900 if upgrading or $300 an year.
Google the real prices, There are too many places you can get PT HD for these prices so I don't want to be biased. And BTW, I doubt that the upgrade will fix your problem. You are doing something wrong as lots of people here are working with hundreds of tracks without issues. We need more info in order to help you. What is your clock and sync reference? Do you work with vid reference input getting triple level sync? Can you screen shot your session setup window? Do you work with DNxHD video or H264? What if you remove all the plugins?
Michael Goorevich Sound Designer / mixer www.goorevich.com PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3 MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24 Last edited by mgoorevich; 09-11-2017 at 11:32 PM. |
in pt 12 it won't be different. You probably have to rethink your bussing setup & workflow I'm afraid. Last edited by Nick Camaron; 09-12-2017 at 02:47 AM. |
I am using the internal clock of the HD Omni. I do not have video reference input, I am using quicktime files, pro res 422. Neither making all plugins inactive nor removing all plugins changes anything. Delay compensation off/on changes nothing. HOWEVER, Everything is back in place if I just run my sessions off of an external thunderbolt drive. Running them off the machine's internal SSD seems to be causing problems. Lesson learned. |
Its extremely important to run video, audio and system each on separate drive.
Michael Goorevich Sound Designer / mixer www.goorevich.com PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3 MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24 |
ADC bug - Offline bounces not in sync | made | Pro Tools 12 | 0 | 11-20-2015 06:26 AM |
Recording early issue in 8.04cs2 | mattyd27 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-08-2010 07:10 AM |
QT bounces out of sync!!!!! but session IS in sync | stormmusic | Post - Surround - Video | 8 | 01-12-2007 07:59 AM |
Mastering Issue (After Bounces) | dane2df | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-05-2006 03:19 AM |
New tracks record out of sync (early) HELP!!! | WildHoney | Pro Tools TDM Systems (Mac) | 2 | 05-25-2005 10:52 PM |
