Old 03-27-2010, 10:26 AM
word_play word_play is offline
Default What should be hooked up to UPS (Uninterrupted Power Supply)
Hey guys, just picked up this:
http://canadacomputers.com/index.php...85&cid=PWP.101
I currently have my DAW and my two LCD monitors (23 inch and 19 inch) connected to battery back up and my studio monitors (KRK Rokit 5's) connected to the surge protection. My question is, and I don't see why it would be a problem just wanted to be safe and ask, is it ok to connect the studio monitors to the battery back up portion of the UPS? According to the LCD screen on the UPS, it is not even at half load with the DAW and lcd monitors connected. What do you guys think?
Thanks.
Old 03-27-2010, 11:20 AM
JMS40 JMS40 is offline
Default Re: What should be hooked up to UPS (Uninterrupted Power Supply)
I only connect monitor's(vid) and computer. Those are the only things I need running in the event of a power failure. And that just gives me time to shut down properly.
Speakers (and everything else) are surge protected but not UPS'd. I wouldn't continue to work during a power outage so I consider it unnecessary.
YMMV
Old 03-27-2010, 12:40 PM
I have a similar sized APC UPS and have everything on it EXCEPT the speakers(powered Event SP8's and Powered sub).
Old 03-27-2010, 12:45 PM
Is there a reasoning behind not putting the speakers on it? Or just not enough room?
Old 03-27-2010, 12:51 PM
DeyBwah DeyBwah is offline
YMMV
That's a great point, I currently have everything connected to my UPS.. and in power outages, I would simply run and switch off everything that was unnecessarily taking up juice and limiting my safe shut down.
Thanks for the tip.
"One should not pursue goals that are easily achieved. One must develop an instinct for what one can just barely achieve through one's greatest efforts."
-Albert Einstein
Windows 7 - Reaper 3 - Lynx Aurora 16 - RME HDSPe AES - DigiMax FS - Eureka - Axiom Pro - Yamaha HS80Ms + HS10W Sub
Old 03-27-2010, 03:40 PM
The speakers are the biggest current draw(outside of the computer) and if the power goes out, I don't need them(and I don't want preamps and such to go down in case I am in record).
Old 03-27-2010, 03:55 PM
caruso7r caruso7r is offline
While it's true that no one would want the live recording session to go down, you have to realize how many UPS units you want to purchase for this situation. While I'm at home, the main thing for me would be the computer, any external hardrives, monitor, and the interface. The reason for these simply is to shutdown the system and wait till the power comes back. It's important to save the session and the drives where everything is at, so the speakers, outboard gear etc, i can live without. In the studio it's a different story.
John
Pro Tools 12.5
Macbook Pro & Windows 7 Ultimate 64 Bit
Old 03-27-2010, 04:15 PM
makes sense.. thanks for the input guys.
Would this UPS (Uninterrupted Power Supply) protect and power my gear? D_Japan macOS 4 07-24-2011 04:23 PM
Uninterrupted Power Supplies word_play 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 03-14-2010 03:02 PM
002 power supply/bad power harness? please help :( djkiller 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-07-2005 08:04 PM
Phantom power and mic with power supply? hotstuff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-20-2005 12:56 PM
BAD POWER HARNESS/POWER SUPPLY!!??HELP!! snuffacation 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-11-2004 03:03 PM
