Assertion error with elastic audio and imported .wav files
If I have Elastic Audio enabled for new tracks, and import any .wav file, I get the following error. The waveform display in the regions goes blank. I can sometimes delete the new track, and drag the converted region back in from the region list, but it sometimes still gives trouble later on (i.e. white noise, or jumbled audio).
Assertion in “/Volumes/Development/vb_protools_8.0.4_cpr?AlturaPorts/NewFileLibs/FileFormat/MacBuild/../../FF/Audio/Elastic/FF_PacketStreamSet.cpp”, line 381 The session is 44.1/24-bit but the files are 44.1/16 so they need to be converted on import. As long as Elastic Audio is off however, I can import these files without issue. At first I figured it was caused by the source of the files I was using, but I tried creating .wav files in multiple applications, on my PC and my Mac, always with the same result. I've been hunting around to see if I'm the only one--anyone else see this? PT 8.0.4 cs2 MacBook Pro 2.33 Intel Core 2 Duo - 3GB - OSX 10.5.8 1TB WD FW audio drive - M-Audio ProFire 2626 |
Re: Assertion error with elastic audio and imported .wav files
Not sure if you are stuck or just reporting a bug. But to ask the obvious question... if you import (and convert) the MP3 can you then enable elastic audio on the track? Or does elastic audio still throw an assertion?
I'm not stuck--there is a workaround: I can make a new session and import the converted split stereo files from the old session's audio files folder. However, as I work with a good number of imported interleaved stereo 16-bit waves, this is not at all convenient. |
I am getting an error that i need help with.
Neo Assertion in "/Volumes/Development/vb_devbranch_boondock/AlturaPorts/SDKs/Neo61/Libraries/Macintosh/Envirments/Alone/.../.../.../.../Source/CNeolnode.cpp", line1242 If anyone can help me I would really appreciate it. |
Elastic Audio Neo Assertion Prob persists | LAStrings | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-14-2012 12:50 PM |
Assertion Error When Right Clicking On Imported Region | Blank Frank | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 03-18-2010 02:12 AM |
Assertion Error line 140, Elastic Audio, Workaround, Questions | phasephucked | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-28-2009 10:05 AM |
assertion error during elastic audio | jrecon | Pro Tools TDM Systems (Mac) | 3 | 10-21-2009 07:27 PM |
How to use elastic audio to conform an imported file | DonaldM | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 20 | 06-30-2008 06:01 AM |
