Old 05-29-2008, 11:08 AM
noharmlessrock noharmlessrock is offline
Default Can Dynamics 2 and EQ 2 coexist with Dynamics 3 and EQ 3?
Hi - I'm all currently running PT 7.4.
But heres something I noticed since I have updated. I don't have my Version 2 of my Dynamic and Eq Plugs. I did a reinstall from my 7.0 disk of just the plugs, and EQ 2 and Dynamics 2 do show up in my plug ins folder, but I still can't pull them up in a PT session.
Does anyone have any tips on having both version 2 and version 3 at the same time?
Old 05-29-2008, 11:46 AM
Slim Shady Slim Shady is offline
Default Re: Can Dynamics 2 and EQ 2 coexist with Dynamics 3 and EQ 3
Doing the re-install from your 7.0 disk was not the way to go. Those versions *may* have been too old for compatibility.
In your "Plug-Ins (Unused)" folder you will find the v2 plugs that the 7.4 install moved there. You can drag those back into the regular "Plug-Ins" folder if you have old sessions that need them, but going forward with new sessions/tracks you should use the v3 of the plugs as eventually the v2 will be phased out completely.
I believe they're all dual-mono only too, so if you're looking for them under Stereo RTAS Plug-ins you won't see them.
Old 05-29-2008, 12:23 PM
Hey Slim
Thanks so much for your help. I have re-installed my plugs from my 7.3 disk, have moved the unused plugs to the right area,
but still can't pull up (ie find) the version 2 plugs even in mono.
I understand this may be fruitless since they will not be compatible for long, but I really liked the simplistic-ness of a lot of those plugs
no problem with dynamics in pt 8 problem with rane series dynamics at pt 8 vageli Pro Tools TDM Systems (Win) 0 01-25-2011 11:00 AM
Expander Gate/Dynamics III vs Drawmer Dynamics DaveSB Pro Tools TDM Systems (Mac) 14 01-31-2007 06:26 AM
dynamics bignick Tips & Tricks 8 03-30-2006 12:45 PM
Dynamics III Vaphoron Pro Tools TDM Systems (Mac) 2 10-02-2005 04:09 PM
Dynamics ? jeam25 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-31-2004 12:42 PM
