Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 05-30-2020, 09:53 PM
juniperian juniperian is offline
Default Re: Lag/spinning beach ball every 10-20 seconds
Me too, just started today out of the blue. After trashing prefs and reinstalling PT didn’t work, I went as far as downgrading from 2020.3 to 2019.5, setting my playback engine to the computer’s built in audio outputs, removing all plugins, disconnecting virtually all peripherals and extra monitors. No luck. Only Pro Tools seems to be affected. Mac Pro 2013 6-core 3.5 GHz, 64 GB RAM HDX2, Mojave.
Old 05-30-2020, 11:42 PM
ariaprayogi ariaprayogi is offline
Me too. 2020.03, Mojave.
I hope they can fix it soon. It's pretty distracting for work.
Old 05-31-2020, 01:26 AM
Alexandr9 Alexandr9 is offline
And for me, it’s impossible to work - it’s wildly annoying. It started suddenly, I didn’t change anything or update it before. It stops glitching when the Internet is off!
Old 05-31-2020, 01:42 AM
jchan jchan is offline
A spinning ball in Pro Tools is for me 99% related to Pro Tools extreme sensitivity / incompatibility with any network activity, wifi might be worse than cable.
Old 05-31-2020, 03:02 AM
Oli P Oli P is offline
Wow...started for me yesterday as well...on 2019.12 Ultimate.
I then uninstalled and installed the latest version...but now it crashes on startup
Called support yesterday, and they promised to call me back same day...but now it's next day...and still no call
www.olipoulsen.com
iMac27 i9 3.6 (late 2019) / 64 GB Ram / OS 10.15.7
Apollo 8 / PT Ultimate 2020.9.1
  #16
Old 05-31-2020, 05:09 AM
Mike Thornton's Avatar
Mike Thornton Mike Thornton is offline
We have posted this article with everything we know so far. We will update it as we learn more.
Mike Thornton MIPS
Chairman Of Production Expert Ltd - home of Pro Tools Expert
  #17
Old 05-31-2020, 06:24 AM
Tim R. Tim R. is offline
Looks like someone in another thread found a simpler workaround than turning off the internet or reinstalling PTs with "Send data to AVID" turned off:
"I just turned off "send anonymous pro tools usage data to avid" inside preferences/operation, restarted PT, and i think it has cleared up, without a reinstall... "
Giving that a shot now.
Tim Reisig
Main System: Pro Tools Ultimate 23.12, HD Native TB, HD OMNI, S3/Artist Transport/Eucontrol 22.20, Apogee Rosetta 800 w/XHD card, Avid 96 I/O
Mac OS 13.2.1, 2018 Mac Mini 3Ghz i5, 32Gig RAM
System 2: Pro Tools 23.9 (no Hardware), Mac OS 13.2.1, MBP (Macbook Air M2, 2022 24Gig Ram)
  #18
Old 05-31-2020, 07:06 AM
RyanC RyanC is offline
Looks like a possible fix is reinstalling, and selecting no when asked to send anonymous data to avid.
Seems to be working on one of two systems here, will test the other later
  #19
Old 05-31-2020, 07:08 AM
I did that...but after updating to 2020.5 PT crashes on launch in the end of the launch sequence.
Also if I disconnect the internet.
www.olipoulsen.com
  #20
Old 05-31-2020, 07:37 AM
I can confirm that in my case, turning off the preference (under operation) to "send data to AVID" has solved the lag issue for me. Thankyou DUC and Mike Thorton at Pro Tools Expert (www.pro-tools-expert.com) for the insight.
Tim Reisig
spinning beach ball monet Pro Tools 2018 2 05-07-2019 12:43 AM
Spinning Beach Ball.... Help StevieDebe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-07-2011 06:40 AM
Spinning Beach Ball Of Death On G5? logandrum Pro Tools TDM Systems (Mac) 0 08-03-2007 12:07 AM
spinning beach ball when doing almost anything... Muzoid Pro Tools TDM Systems (Mac) 4 01-01-2006 08:57 AM
Going NUTS w/ Spinning Beach BALL... pls hlp Aluminum Jockey Pro Tools TDM Systems (Mac) 36 09-08-2004 05:10 AM
