Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 09-27-2018, 05:52 AM
jpsexton's Avatar
jpsexton jpsexton is offline
Default Low Latency Interfaces?
Can anyone share their experiences with LL Interfaces such as RME or Quantum?
Is it possible with today's powerful PC's to simply monitor and work within Pro Tools without having to resort to direct monitoring thru the interface software?
I switched from a TDM system to UAD and it works but, I have never really been happy with having to use the UAD console. It just seems like a work around. I miss the simplicity of just working in Pro Tools. TDM just worked!
I'm working on a project now that will probably finish up before the end of the year. After that I'm probably going to get out of the UAD ecosystem.
HDX isn't an option because I refuse to pay the inflated maintenance fees.
Is there an interface option that will do what I want?
Intel - Core i7-8700 3.2GHz 6-Core Processor
Asus - Prime Z370-A ATX Motherboard
Asus Thund​erbolt III​ AIC
16GB (2 x 8GB) DDR4-2133 Memory
Patriot - Spark 256GB SSD System Drive
Patriot - Ignite 480GB SSD Work Drive
Hisense 43" 4K Display
Presonus Quantum
OS - Windows 10 Pro
Handle every stressful situation like a dog. If you can't eat it or play with it, Just pee on it and walk away.
Old 09-27-2018, 12:38 PM
junkgear's Avatar
junkgear junkgear is offline
Default Re: Low Latency Interfaces?
I currently run a Quantum interface under Windows and can achieve 4 ms total latency, which I can not detect and always track without direct monitoring.
I have also used the Focusrite TB Clarett interface, which is also very good, but the Quantum drivers seem more efficient where I can user a smaller buffer without issues.
The Focusrite preamps have more character, and it's a perfectly usable interface, but if sheer performance is your goal, then go for the Quantum.
Will
System Details
Old 09-27-2018, 12:47 PM
amagras amagras is offline
I have a Native Instruments KA6 and I track guitar and bass with virtually no latency, even in sessions with heavy plugin count where I have to use 256 or 512 I can barely notice it (provided that none of the plugins used imparts a large value to ADC). The little box really excels in performance!
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 09-27-2018, 05:48 PM
Since the OP is used to the UA interface, just be aware of one detail. Without the Apollo AND the UA "console", you will not be able to track with any UAD plugins. The latency will not allow it, outside of the Apollo's console(on my HD/Native rig, every UAD plugin reports at least 1100 samples of latency). If you don't need UAD plugins while tracking, then it won't be a problem
Old 09-28-2018, 07:09 PM
jpsexton's Avatar
If I change from the Apollo, I'll likely get out of the UAD ecosystem altogether. Their all or nothing policy concerning reselling plugins has kept me from investing to heavily. The EMT140 is the only one I'll miss...
Presonus Quantum
OS - Windows 10 Pro
Old 09-28-2018, 11:53 PM
YYR123's Avatar
YYR123 YYR123 is offline
Let’s not go there b/c I would miss more than a few 🤭
Daniel
Interfaces and Latency Questions kaldyn Getting Started 19 06-15-2014 08:50 AM
Latency between Digi 003 and audio interfaces crazy_ow Pro Tools 9 12 08-26-2012 10:51 AM
Low latency monitoring in non Avid interfaces flautista Pro Tools 10 11 01-08-2012 06:13 PM
Maudio interfaces, any better latency than others? angela howard Pro Tools M-Powered (Mac) 4 07-08-2005 05:15 AM
OT: Latency Issues with USB MIDI interfaces butter_lover 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-31-2003 06:15 PM
