Old 12-15-2012, 02:33 AM
Caatalyst Caatalyst is offline
Default Windows 7 Background services
Hi everyone,
I'm on a bit of a optimization mission at the moment trying to get Pro Tools as stable as possible. It still seems a bit sluggish at times.
First I wanted to ask if anybody knows how useful the following background services are and if I should keep them running;
- Intel(R) Rapid Storage Technology
- Intel(R) Intergrated Clock Controller Service - Intel (R) ICCS
- InstallDriver Table Manager
- Intel(R) ProSet Monitoring Services
Startup
- Delayed Launcher (Intel Corporation)
- Windows 7 DDK Provider
I've also disabled all of the 'C state' options in BIOS but have left turbo core enabled because for some reason I lose my overclock settings. I've been monitoring the core speed of my processor and it's sat at 4.4Ghz it does fluciate slightly but only around 5 or 6 mhz.
Thanks in advance for any responses
Pro Tools 12.4 | Focusrite Scarlett 6i6 | Gigabyte X79-UD3 | Intel i7 3820 2011 LGA | GeIL EVO Leggera 16GB 4x4GB | MSI Nvidia 970 | Corsair XT 850 watt PSU
Old 08-31-2014, 04:22 AM
jzatorski jzatorski is offline
Default Re: Windows 7 Background services
Hey there. I have just been on a mission to source and destroy the cause of distortion in Protools 8/11 audio output when not in low latency mode, and after 3 weeks work, I have determined conclusively (at least in my instance) that the Intel Rapid Storage Technology user interface was the cause of all my grief!
I am running raid 10 disk, and this is the UI for monitoring disk status, and Protools clearly hates it. If I uninstall that software, the distortion that has been ruining my life is gone.
I am unsure whether your service is running as a consequence of having that software running, or whether it is just running in the background to manage the disks. Only you would know that...
In any case, I think that one can see the raid drive status on bootup, and I can live with having to look at that instead of the UI, if Protools will behave without it!!!
Old 08-31-2014, 07:34 AM
Originally Posted by Caatalyst View Post
Hi everyone,
Startup
You are Oc'ing the 3820 to 4.4 w Turbo fluctuations to 5.0?? 5 MHz fluctuations are also not small. I would be worried about the machine catching on fire!!! You really need to look at your temps. You could be seeing sluggishness in PT because your temps are rising past a safe point. I could see this processor functioning normally w proper cooling at 4 to 4.2 ghz somewhere and keep turbo off.
Otherwise you can kill both startup options, rapid storage and Pro set. Google the others and see if they are necessary.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Unnecessary XP background Services? Rowen Caplan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-15-2011 12:14 PM
background services & system cache options changes? Kirby B. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-12-2010 10:44 AM
SO... Programs, System Cache or Background Services? GordonFreeman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-24-2009 02:20 PM
Set Processor Scheduling to Background Services Fullsound Recording Pro Tools TDM Systems (Win) 4 08-08-2008 11:30 AM
Windows services clausiii 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-04-2006 10:18 AM
