Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 01-21-2020, 04:52 PM
unkJE unkJE is offline
Default SSL’s new 24-bit/192kHz budget audio interfaces - SSL 2 and SSL 2+
https://www.musicradar.com/news/namm...ordable-prices
$230/£150/€180 for the SSL 2, and $280/£200/€240 for the SSL 2+ (all prices are minus VAT/tax)
Both interfaces ship with the SSL Production Pack, a software bundle that contains the SSL Native Vocalstrip 2 and Drumstrip plugins (plus a 6-month trial of the other ones in the collection), Avid Pro Tools | First, Ableton Live Lite, NI Hybrid Keys and Komplete Start, and 1.5GB of samples from Loopcloud.
SSL 2 USB Audio Interface
https://youtu.be/GV61MhvhVfs
SSL 2+ USB Audio Interface
https://youtu.be/qWyq9x9otJg
Pro Tools 2019.12 and 12.5.1 HD - Studio One 4 Pro - Win10 64 Pro – Lenovo W520 ThinkPads & 433830U Docks – Mbox 3 Pro - Axiom Pro 49 - AIR Mini 32
Old 01-21-2020, 06:34 PM
Default Re: SSL’s new 24-bit/192kHz budget audio interfaces - SSL 2 and SSL 2+
https://www.solidstatelogic.com/interfaces
https://www.solidstatelogic.com/interfaces/features
SSL 2 & SSL 2+
System requirements and Specs:
Mac OS 10.11 and above | Class-Compliant, Plug-and-play
Windows 8.1, Windows 10 | Install included ASIO/WDM driver
Connectivity
USB 2.0 Type C Connector (Box includes Type C to C and Type C to A)
Mic Preamps
EIN: -130.5 dB
Gain Range: 62 dB
Instrument/Line
Max Instrument Input Level: +15 dBu
Max Line Input Level: +24 dBu
*Specs (Measured to AES17 Standards)
Monitor Outputs
Dynamic Range: 112 dB
Max Output Level: + 12.5 dBu
Headphone Output(s)
Dynamic Range: 111 dB
Max Output: +10 dBu
Sample rates
44.1, 48, 88.2, 96, 176.4, 192 kHz
SSL2+ Recording with Pro Tools First
https://youtu.be/C7WWYsKp4fY
SSL 2+ Separate Headphone Mixes
https://youtu.be/jTVRq_boHl4
Setup SSL 2+ On windows
https://youtu.be/cK6t6MS-wpE
SSL 2+ Setup On Mac
https://youtu.be/HLVsCXYuRBk
Quick-Start Guides & User Guides
https://www.solidstatelogic.com/support/downloads
https://solidstatelogic.zendesk.com/...e-blanced-out-
https://solidstatelogic.zendesk.com/...on-an-iPad-iOS
https://solidstatelogic.zendesk.com/...udio-Interface
For those looking to use the SSL 2 or SSL 2+ USB audio interface with a Thunderbolt 2 port on Mac you will require a Thunderbolt 2 to USB connector.
Those who have Thunderbolt 3 connections on their Mac will be able to use the provided USB-C to USB-C cable. This because Thunderbolt 3 is also USB-C enabled.
Old 01-21-2020, 07:28 PM
Below info quoted directly from:
https://www.solidstatelogic.com/stud...20native/ilok2
Includes 2 Perpetual licenses:
SSL Native™ Vocalstrip 2
https://youtu.be/RRambEQAP7A
One Stop Vocal Processing.
The fast track to a professional vocal sound.
Vocalstrip 2 is an application specific plug-in that draws upon decades of SSL professional engineering expertise to combine the right four processing elements to create the simple route to professional vocal recordings. Combining EQ and dynamics sections with essential vocal processors, Vocalstrip 2 aims to bring power, character and clarity to vocal tracks from a single interface. Vocalstrip 2 solves the challenges of producing great vocal recordings with four processing tools carefully selected and calibrated to deliver great results every time.
Key Features
• 4 selected vocal processing tools with a unique SSL twist
• Comparative analysis & dynamic envelope based De-esser
• Comparative analysis & dynamic envelope based De-ploser
• 3-band SSL EQ with High-Pass, 'asymmetric notch' and 'air' bands
• Compander featuring compression, downwards expansion and output drive
• Informative visual feedback showing EQ curves and real time FFT overlay
SSL Native™ Drumstrip
https://youtu.be/qlGD2qGRDyQ
Clarity, punch and power for your drums
The simple path to better drum tracks.
The secret to making an average drum recording sound incredible can be elusive. It takes the right combination of processors, with the perfect sonic character, in the correct configuration and tweaked in the right way. Drumstrip takes drum sounds from ordinary and average to vibrant and exhilarating in a few quick, easy steps.
Plug in, switch on and experiment. Drumstrip handles the hard part; putting the right selection of fantastic sounding processing tools in your hands in an instant. With Drumstrip, DAW users can attain increased presence, clarity and detail in their drum tracks; reduce spill in individual tracks; restore natural brightness; achieve greater perceived loudness; shorten or lengthen the attack and sustain of percussive signals; tighten up booming toms; make kicks and snares stand out in a mix; and parallel compress room mics.
Key Features
• Carefully selected collection of five audio processing tools
• Transient shaper with Transient Invert to bring the attack phase of your drums to life
• Transient Shaper Audition enables you to isolate and monitor the effect of the Transient Shaper
• Dedicated drum Gate with range and independent open and close threshold controls
• High Frequency Enhancer to invigorate top end
• Low Frequency Enhancer to improve bass frequencies
• The classic SSL Listen Mic Compressor with additional bypass function to alter the legendary band-limited compression to full range compression
• Adjustable processor order—because a different processing order is required for different types of drums
• Input & Output Level metering with additional RMS meters
Old 01-22-2020, 12:03 AM
JCBigler's Avatar
JCBigler JCBigler is offline
It's definitely a cool looking little interface.
I almost bought one to use for mixing and editing in the hotel room while on tour. But I went with an Apogee One instead because it's even smaller and more compact.
Justice C. Bigler
www.justicebigler.com
Head Audio/A1 Blue Man Group North American Tour
Lenovo P50: quad-core i7-6820hq, 64GB, 2TB SSD, Win 10 Pro / HD|Native-TB / Protools Ultimate 2019.12
Home/mobile: Focusrite Red 8Pre / Clarett 4Pre
Road/hotel: Roland OctaCaputre / Apogee One
Old 01-22-2020, 10:32 AM
TNM TNM is online now
if anyone buys one and already has or doesn't want the vocalstrip duende plugin, let me know and i'll buy it from you for the sale price (which only seems to be once a year now so you get cash and I skip the line), 50 bucks.
These look pretty nice for the price.. I wonder if they are class compliant or have a decent driver.. class compliant stuff sadly can't report the real latency of the device nor include the adda conversion in what is reported to the DAW, so i always prefer a nice accurate fast driver if possible. I wonder which way SSL go.
Still, cheap and travel friendly.
(I still have my mbox 3 for that but we know that there'll be no Catalina drivers so it's time is up).
-iMac Pro 3.2ghz 8 Core, 64GB Ram, Vega 56, OS 10.14.6/Win10 Pro, TB3 Dock & 4xSSD, UA Apollo x3 + Octopre x3, Microlite x2, Midi Synths galore, PT 2019.12
-MBP 15" 2.8ghz 4 core, 16gb ram, 750M, dual boot OS 10.13.6/10.14.6, On board analog audio out, PT 2018/2019
-Whenever I launch Pro Tools, I get wet.(™)
Recording 192khz gives audio error 6061? olamo macOS 0 03-18-2012 01:53 PM
The market for surround mixing on low budget interfaces nst7 Post - Surround - Video 3 01-22-2011 02:49 AM
I cant go to 192KHZ KINGDRAGON Tips & Tricks 2 01-30-2010 12:57 AM
