Go Back   Avid Pro Audio Community > Pro Mixing > Avid S1, S3, Dock and Control
Old 01-09-2020, 09:01 AM
mixboy bob mixboy bob is offline
Default Re: fader automation stops during pass
Confirmed here, as well.
http://www.robburrell.com
PTHD Ultimate 2019.12/2018 Mac Mini 3.2ghz 6-core i7/32GB RAM/Aja T-Tap/Akitio Thunder 3 Quad Mini with 4TB SSD drives/Focusrite 16Line/UAD-2 Octo PCIe in Sonnet chassis/32 Channel S1/Dock with (5) 2019 Amazon Fire HD 10 Tablets/XMON//11.1.4 Dolby Atmos Setup
Old 01-09-2020, 09:38 PM
Dror520 Dror520 is offline
Default No Write mode from S1
Hey all,
I hope I'm not doing anything really dumb, but when I use the Rec (A) button on the S1 to switch between the different automation modes I only get read, touch, latch and off. I don't have write. I have to use the mouse to switch it to write.
Does anybody else have this problem?
Thanks!
Old 01-10-2020, 01:17 AM
Default Re: No Write mode from S1
Originally Posted by Southsidemusic View Post
Merged for better exposure./
From what I've seen in this thread, nobody pointed out that the write mode isn't available from the S1. It's all about the automation problem after 50 seconds.
Thanks!
Old 01-10-2020, 02:01 AM
Southsidemusic's Avatar
Thanks!
You are right. Lets see if Eddie can help you as he frequent these threads and I will also ping them so someone can give you the correct answers.
Best Regards
Christopher
South Side Music Group
WEBHOME
Old 01-10-2020, 10:20 AM
Thank you!
  #16
Old 01-10-2020, 11:12 AM
EddieJones's Avatar
Write was removed from the cycling modes as it was extremely dangerous and caused some users to wipe over automation. This is now the same as the S6.
The dropping out of write after 50 secs issue we are still investigating.
  #17
Old 01-10-2020, 11:45 AM
Oh ok, so the only way to access the write mode is either from pro tools or to create a soft key command?
  #18
Old 01-10-2020, 11:46 AM
EddieJones's Avatar
Or the drop down in the Avid Control App
  #19
Old 01-10-2020, 11:54 AM
Oh right! thanks for help!
  #20
Old 01-10-2020, 12:03 PM
Thank you Eddie for the quick help and info!
Best Regards
Christopher
WEBHOME
AUTOMATION TO DENSE then stops..... I have no automation Weird Audio Pro Tools TDM Systems (Mac) 1 12-07-2012 06:50 AM
Low/High Pass Filter Automation Help Funkle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-08-2010 10:23 AM
automation problems. the first pass doesn't stick londonsoundbloke 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-03-2007 06:14 AM
automation problems. the first pass doesn't stick londonsoundbloke 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-03-2007 09:21 AM
HOWTO, audio file automation during record pass JFreak Pro Tools TDM Systems (Mac) 1 01-15-2007 10:00 AM
