Old 01-07-2009, 03:19 AM
xyzt xyzt is offline
Default What was the first computer Pro Tools (Sound Tools) run on.
Hallo All,
I'm doing some research for an historical project on DAW's. On wikipedia I found that "Sound tools" later to be rebranded as Pro Tools 1 was first released for an Apple computer.
My question is what system exactly was it.
Apple II
Apple IIgs
Macintosh II
Etc.
Here is the article on wikipedia
http://en.wikipedia.org/wiki/Digital_audio_workstation
I hope someone has this knowledge and could provide the answer.
If someone has foto's of the packaging, screendumps, manual or the card itself. I would be more than delighted.
With regards,
xyzt
Old 01-07-2009, 05:07 AM
bobo mark bobo mark is offline
Default Re: What was the first computer Pro Tools (Sound Tools) run on.
Macintosh II... 5 Nubus slot. Sound Tools is pre ProTools DAW. i still have Sound Desinger II manuel if u needed. as well as TuboSyn too.
Regards
Bobo
Old 01-07-2009, 05:28 AM
crizdee's Avatar
crizdee crizdee is offline
i still have my "Atari" soundtools SDII system. around 1985-1986 i think
Atari Mega ste4
soundcard inside Atari
external analog box
external digital box
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-07-2009, 06:45 AM
Jeff D. Jeff D. is offline
I bought Sound Tools 2 weeks after it was introduced, and bought a Mac IIx to put it in.
Been using PT ever since!
Jeff D.
www.jephthastudios.com
Old 01-07-2009, 07:06 AM
jeremyroberts jeremyroberts is offline
Sound Designer for the Emulator II worked with just my MacPlus (serial interface) in 1986
I also had a version of it for the Ensoniq Mirage.
This was at least a year or 2 before Sound Tools.
--Jeremy
Old 01-07-2009, 07:19 AM
Eric Lambert's Avatar
Apple II
Good lord - I can't imagine how that would work. I used to run out of RAM after less than an hour's worth of programming (back when you could actually write line code). SoundTools wouldn't have been allowed to use many "tools" on this machine.
Old 01-07-2009, 08:53 AM
adesound adesound is offline
In 1988, my first system was Sound Tools 2 on a Mac IIci. At that time, I used a secondary program call Deck, that gave me a 4 track editor, and Opcode Studio Vision for Midi production. I've been a Pro Tools guy ever since.
Old 01-07-2009, 12:47 PM
SessionKat SessionKat is offline
My 1st digital system as well. My Mac IIci had and 80MB internal drive. Wow!
I also used a DAT-IO, eventually adding Samplecell II. What a great rig, all-in-all. Bought a 1GB hard drive for $1400 or something outrageous.
Yikes, we have evolved!
-tv
Tim vdB
Avid Audio
"There's a fine line between stupid and clever."
Old 01-07-2009, 04:51 PM
crizdee's Avatar
-tv
Yep, 30 years to finally get midi mute note
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-07-2009, 05:23 PM
NuBus NuBus is offline
Ah I miss my Mac IIfx
I think they had a card for the SE30
I think New England Digital was the first DAW with the Synclavier
No sound from my computer speakers with Pro Tools 9 kalashatt Getting Started 1 05-28-2013 09:38 AM
Constant cracking sound even when not on Pro Tools after reformating my computer popolloh Windows 3 08-22-2012 06:15 PM
Installing Pro tools M powered LE8 and Pro tools LE8 in my computer yukiaroma Pro Tools M-Powered (Mac) 0 06-15-2012 01:39 PM
Audacity Sound, Reaper Sound, Pro Tools NO SOUND RoganX Pro Tools 10 3 03-18-2012 09:06 PM
How do i get pro tools sound out of computer and visa versa stevier 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-11-2011 07:37 AM
