Re: Drum Miking
I have the AKG Kick Drum/Bass Microphone. Yet it just does not seem deep enough. I will try a blanket, pillow and see if that helps some. Thanks
Re: Drum Miking
Start with mic placement, then check your batter head and resonant head tuning. Do you have any dampning in the kick?
FBR recording - https://www.facebook.com/fromthebase...cordsrecording @FBRrecording - Instagram Rig MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors |
Re: Drum Miking
It is my son's kit so I have no clue what he has yet I will ask him and we will figure something close overtime. Thanks
Re: Drum Miking
Which is the batter head, the one in front farthest from the drummer and the resonant head close to the drummer? I know nothing about drums / My son plays them so maybe he knows, not sure. No we don't have any damping like a blanket or pillow inside, we will try that and we will try more mic positions. Were just looking for that thump in your chest, right now it just seems weak and more towards your head. But thank you for some direction on where to start. It just does not seem to have any low frequency. ty
Re: Drum Miking
Hey Sable,
The batter head is the side that the kick peddle hits, the resonant is sometimes a ported head. This is so you can put the kick mic right inside the drum. As for that thump, there will be multiple factors in order to get that. As mentioned tuning, but it could also be your monitoring setup. If you room isn't ideal for listening, that thump may actually be there, but it's cancelling things out. Have you checked the kick drum sound in a car, headphones, etc...? In my studio, I use Equator d5's these are a critical listening speaker. If I make a kick drum sound that it's hitting me in the chest, then I end up with WAY too much low end. What particular kick drum sound are you looking for? Here's a link to some helpful EQ tips: http://www.presonus.com/community/Le...Terms-and-Tips Another option that may help you out is Slate drums Trigger or drummagog. Then you can just scroll through a bunch of kick samples and use drum replacement. Getting good drum sounds takes years of practice, good rooms, great sounding drums, good mics and good mic pres.
#16
Re: Drum Miking
#17
Re: Drum Miking
When PT's completely locked up, did you get any error message? What interface are you using? What is your playback engine setting? What buffer size? Are you recording to a separate drive?
#18
Re: Drum Miking
#19
Re: Drum Miking
Buy a drum key. They are cheap, like, under ten dollars cheap. There is no excuse for not owning at least one.
Practise tuning your drums. If you don't own your own drum kit, rent one for a few days just to practise tuning them. You don't even need to know how to play them (but it sort of helps). You will find that there is a nearly endless variety of different tones that you can get from a drum kit just by tuning it, and playing with different dampening options. Even more tonal options are available if you have a selection of different types of drum heads to chose from. If you can make the kit sound good in the room, you will find it is WORLDS easier to make it sound good on tape, and this will be true regardless of what mics you use. Everybody loves to talk drum mics and drum mic placement, and these are important, but they're basically moot if you don't know how to make the drums sound right acoustically. |
Drum Miking uestion | automatic8 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 09-02-2009 02:40 AM |
Kick drum miking | xterraguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 22 | 03-12-2009 05:40 AM |
Drum Miking with 002 and PTLE | eminentbliss | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-15-2004 02:15 PM |
drum miking | JFreak | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-31-2003 10:28 AM |
Drum Overhead Miking? | Erik Braund | Tips & Tricks | 18 | 12-13-2001 06:35 AM |
