Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire and USB Audio Interfaces (Mac)
Old 12-31-2013, 01:08 AM
liferhythm9 liferhythm9 is offline
Default Fast track c400 drawing too much power
Hello All,
My Fast track c400 was disabled saying that it was drawing too much power from my macbook pro 13".
It is now with Avid service center.
My question is when it is back (repaired or replaced) do you guys suggest me to use a powered usb hub to use the c400. I just dont want the same problem to occur again.
Thanks again.
Nupus
Old 12-31-2013, 08:17 AM
JoelG's Avatar
JoelG JoelG is offline
Default Re: Fast track c400 drawing too much power
It sounds like a hardware issue with the C400 itself, I don't think you will need a USB hub.
Joel
Jame Space:
HP Elite 6300 / Core i5 3570 / 12GB RAM / Win 10 Pro
Pro Tools 12 HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Intel S5000PSL / 2 x Xeon E5450 / 32GB RAM / Win 10 Pro
Pro Tools 12 HD / M-Audio Project Mix IO
Rig:
Eleven Rack / ART SLA1 / Fender Mustang V 412 / FCB1010 w/ EurekaPROM
Old 01-01-2014, 10:54 PM
Thanks Joel,
Yes it was a hardware issue and the components were burnt.
But now when I will get a replacement I was thinking just to avoid the same issue again i could use a USB hub with powere adaptor so that the c400 uses the hub's power instead of drawing it form the macbook and focus on its job.
Any more views on my thought please ????
Old 01-02-2014, 07:08 AM
JoelG's Avatar
I think it would be unnecessary, unless there is a physical problem with the USB port on the Mac. In which case the hub probably wont work either.
Joel
Jame Space:
Home:
Rig:
Old 01-03-2014, 01:46 AM
Mac's usb port works fine..I checked with other devices..
Anyways will check the new device. Hope everything goes fine
Fast Track c400 issues (help) stereopole FireWire and USB Audio Interfaces (Win) 8 01-11-2016 06:53 AM
Fast Track C400 w/ PT11 ?? sandersonc84 Pro Tools 11 1 07-05-2013 04:44 PM
PT10.3 and Fast Track C400 frcjt Pro Tools Software (Mac) 2 09-16-2012 11:07 AM
Problems with New Fast Track C400 maestrochase Pro Tools M-Powered (Mac) 2 01-17-2012 04:49 PM
Fast Track c400 Suddenly Clear Pro Tools M-Powered (Win) 3 10-29-2011 03:17 PM
