Old 08-27-2002, 07:41 PM
dpdemo dpdemo is offline
Default access to B Interface Setup
I can't seem to access the B interface to change settings (sample rate, digital input, etc) vai the Hardware setup panel. Also, can only get the A interface with Windows, Show Session Setup screen
Any ideas what I need to do?
(PT 5.0 on WinNT sp6)
dpd
Ex-Radio Station Engineer
Old 08-29-2002, 07:47 PM
steve at Your Heaven steve at Your Heaven is offline
Default Re: access to B Interface Setup
First, I think the Show Session setup only shows tracks 1 and 2 of the primary interface, so don't look for more there. The rest of the question indicates that there is a connection problem, or that you have not configured something correctly during setup. If there are two cards in the computer (a 'Mix Core' and a 'Mix Farm' card), are they connected together properly? If one card only ('Mix Core'), and you have two interfaces, are they properly connected to the card via the special 'Y' cable? If the hardware is all correct, did you do the 'Setups/PlaybackEngine…' routine? Also, be familiar with the process in the HardwareSetupPanel - you first select the card to which the peripheral is attached ('Card'), and afterwards select the device ('Interface Port' A or B) that you want to adjust.
steve
Your Heaven
Can't access HD Native interface in Logic 9 LesB Pro Tools HDX & HD Native Systems (Mac) 7 01-02-2015 08:08 AM
Can't Access Hardware Setup Dialogue in Pro Tools andylou 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-15-2011 03:19 AM
Can not access Digidesign CoreAudio Setup 6.4 D_Japan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-14-2005 07:31 PM
Can't access Hardware Setup Dialog??? Jepse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-18-2005 09:54 AM
OMS Setup: Interface Req'd? Setup referrences? eltornado 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-19-2000 04:17 PM
