Old 09-20-2019, 02:11 AM
aneesholv aneesholv is offline
Default Mic input always in the monitor
Hi
I Am using Protools 12.3 with RME Fireface UFX 11 and Bigknob .Recently Iam facing a problem that Mic input always in the Monitor even if record is enabled or not in the track. Kindly suggest a solution .
Regards
Aneesh T V
Old 09-20-2019, 02:22 AM
Default Re: Mic input always in the monitor
You have hardware monitoring (aka TotalMix) enabled in the interface. Nothing to do with Pro Tools.
Read about TotalMix/TotalMix FX in the User Guide for you interface.
You should work out how to use all this, you can play with TotalMix without Pro Tools running and get comfortable with all it can do... you may well want to be using it for low latency monitoring.
Old 09-20-2019, 09:19 AM
The Weed's Avatar
The Weed The Weed is offline
To add to what Darryl has said, I had an MBK with my UFX and sold it and got an RME ARC USB Controller. It's fully integrated with the UFX and TotalMix, even more so with the UFXII, and allows the audio to go directly from the UFX to wherever you route it - a software digital mixer. And Snapshots allow you to store 8 recallable setups. Total Mix is very, very powerful, but does have a steep learning curve. It's worth it.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 09-22-2019, 12:40 AM
Hi
I had done a thorough check up and found that mic input is always in the monitor even if protools workstation computer is not turn on . How can I enable/disable hardware monitoring ( TotalMix) in the interface. Can you brief about TotalMix
Old 09-22-2019, 12:46 AM
Originally Posted by aneesholv View Post
Hi
Yes it's always on, we knew that already, this has nothing to do with Pro Tools.
You need to read the manual. This is more complex than can be answer in a simpel post, and we are not going to reproduce the whole documentation here.
EDIT: If you work through the documentation and get stuck with a specific thing or question--ask that here, thats the sort of thing folks here can help with.
audio input tracks sent to one aux track - how do i monitor JUST the aux input track? awhile 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-17-2010 07:50 AM
How do I monitor my input Strebor24 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 05-06-2010 11:18 AM
How do I monitor input on my 888/24? Micheal Pro Tools TDM Systems (Mac) 2 02-04-2007 06:56 PM
switch auto input and input only monitor with midiprotocol mmestudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-27-2003 03:51 PM
How to toggle between "auto input" and "input monitor" with PC?? Camilo Orozco ProControl, Control|24, Command|8 2 04-23-2001 01:05 PM
