Core Audio
Can someone please tell me why Core Audio launches.....occasionally....when I launch Safari? It does not happen everytime and I cannot see any common reason why it does open in this sporadic manner.
This is annoying because I will go surf the web and then go to open a PT session and I will be told that the hardware is in use by another program. I then have to Force Quit Core Audio to proceed. Since I run my computer audio and the 002 Main outs through a mixer and NEVER use iTunes or any other audio through my 002 hardware.....do I even need Core Audio?
Mac Studio M2 Max 12-core CPU, 38-core GPU, 16-core Neural Engine 64 GB memory 2TB Solid State Drive Thunderbolt 4 Sonoma 14.1.2 Pro Tools 2023.9 Universal Audio Apollo 8P (TB3 Option Card installed) |
Re: Core Audio
In that case, no, you don't need it. Just bare in mind if you want to use any third part apps with your 002, Logic, Peak, FCP etc. you won't be able to without core audio.
Cheers Is built in audio set under system preferences or digi hardware, try trashing the safari prefs.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D --- iCON Photography |
Re: Core Audio
I don't believe it, this has just started happening to me as well, it also happens when i launch MSN messenger, unfortunatly i need core audio, any takers???
Cheers
Re: Core Audio
If you have your "Default Output" set to Digi HW, then anytime an app wants to make any sound (ie a beep), the CoreAudio Manager will be launched. If you want to avoid this, you can set your Default Output to something other than Digi HW.
digi-eng |
Re: Core Audio
All of my audio on my iMac is set to 'bulit in audio', that way the only time the mbox is used is when Pro Tools is launched. It's MSN messenger that is launching core audio, not sure how to stop it????
Cheers
Re: Core Audio
I've managed to sort it, i went in to audio/midi device setup under utilities. My built in audio sample rate was set to 96k, not sure how i've never touched it. I set it back to 44.1 and messenger has stopped launching core audio.
Result!
Re: Core Audio
Result!
Re: Core Audio
Well my default output is set to the Revolution 7.1 soundcard and my setting is 44.1 in the Audio Midi setup, so while helpful hints they don't apply here for me.
Just now I booted and I saw the momentary brief image of the Core Audio manager window open up.....checked the dock and there it was in all it's annoying glory. I appreciate the responses, thanks.
Digi 002-using FW & core-audio drivers to output audio to mac WITHOUT using ProTools | DaveZ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 04-12-2012 12:53 PM |
core audio conects , but no audio passing threw | audiomania | Pro Tools TDM Systems (Mac) | 2 | 08-23-2006 07:41 AM |
Pcie core + Core audio + Tiger, does it work? | fantomaz | Pro Tools TDM Systems (Mac) | 0 | 12-21-2005 01:04 PM |
Problems w/Core Midi and core audio MBox 6.1 | letrev | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-03-2003 01:43 PM |
Will the core audio driver enable audio units ? | linpaws | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-16-2003 02:01 AM |
