Old 03-17-2018, 01:20 PM
PRSWILL PRSWILL is offline
Default Eleven Rack and Ground Control Sync
So I have never been able to figure this out. When I configure a tone in the Eleven rack and plug in the Ground control to use it, the Lights that coinside with each effect do not synch up with the ground control.
This is frustratung when using live- I'd like to be able to scroll through settings and have the corresponding lights on the GC tell me which effects/ compressors/etc are on without having to look at the Eleven rack each time.
Can someone please provide some advise on how to make this happen?
Old 03-19-2018, 06:19 AM
Default Re: Eleven Rack and Ground Control Sync
Never Mind- Got it...
Old 04-03-2018, 12:28 AM
Cyguitar Cyguitar is offline
So, what did you do to get it to sync up? I am new to the 11R too. I have the Sweetwater bundle with the 11R and the Ground Control Pro. They come with artist presets.
Old 04-04-2018, 12:57 AM
stormstudios stormstudios is offline
You have to save the GC patch with the lights in the initial state the 11R patch are at. Once it's been 'manually sync'ed' (for lack of a better term) then the GC will show the appropriate On / Off state. It doesn't actually get the indication from the 11R.
Sorry if Im not describing it clearly.
Eleven Rack and Ground Control Pro prodigy_ed Eleven Rack 4 04-07-2018 08:34 AM
Eleven Rack & Updating Ground Control Pro to presets TheGuitarGrandpa Eleven Rack 0 11-30-2017 08:53 AM
Eleven Rack and Ground Control Pro Problem(s) wpawley Eleven Rack 3 07-03-2016 01:51 PM
Eleven Rack & Ground Control Pro Template guitarorth Eleven Rack 2 03-10-2012 01:33 PM
Eleven Rack Ground Control Pro Axiom 25 Scott Paige Eleven Rack 1 10-19-2010 02:15 AM
