Reverb On Multiple Instruments
I am sure this is laughable but this issue has been on my mind. I will soon begin mixing a few projects at home and a dilemma about reverb has been haunting me. If I inject some reverb on my snare that is timed to last at least from snare hit to snare hit, technically the reverb will be heard ALL the time. Which led me to think about adding some reverb to the guitars. If the reverb from the snare is present throughout all of the song, why would I need it on the guitars since technically it is present there already from the snare? I suppose I can certainly use a different type, amount, length etc of reverb on the guitars than I did on the snare, but I am thinking that the verb from the snare could theoretically be sufficient as a color that effects the track enough which would allow me to leave the guitars and for that matter, most if not all other instrument tracks - dry.
2020 Mac Mini I7 3.2GHz, 36 GB Ram, Catalina, ProTools 2018.12.0 UAudio X6, Axiom Pro S49 MkII, Maschine MKIII. |
Re: Reverb On Multiple Instruments
Mixing is an Art. Yes there are Professional and Non Professional things can do or not do, but when it comes down to it, its your Mix you can do whatever you want. Nothing is right or wrong as they say "It is what it is"
Producer/Engineer/Musician RIAA Platinum Sales Award: Lisa Stansfield "Affection" Main: Model: Dell 5750 Precision Workstation OS: Windows 11 Pro 64bit CPU:*Intel Core Processor i7-10750H (6 Core, 12MB Cache, 2.60 GHz to 5.00 GHz, Memory:64GB, 2X32GB,DDR4 2933Mhz Non-ECC OS M.2 512GB PCIe NVMe, Record Intel 1TB SSD, 2T SSD, 1TB SSD Focusrite Scarlett 18i20 3rd Gen AVID Pro Tools 2023.12 JBL LSR4328P 8" JBL LSR310S 10 inch Powered Studio Subwoofer* Yamaha HS50M Studio Monitors Alesis Elevate 3 Studio Monitors M-Audio Axiom 61 Midi Controller |
Some like to feed all the instruments to the same reverb, to create the "glue" of a common space. And my last "general' tip, the faster the song, the shorter the reverb time(so the idea of having a reverb tail last from a snare hit, all the way to the next snare hit......not a good idea, but might be a cool special effect to use once or twice). Anything overdone, will take away from the song, whether its too much reverb, too many guitars, too much bass........your favorite commercial songs are a good place to start
Thanks for the replies but I think still not hitting on my dilemma. For example, if I have just two channels, one recording a single snare hit, the other recording a single guitar note, if they were both panned up the middle and both receiving the same reverb and amount of signal of reverb from an aux reverb send, would it sound the same if I muted the reverb on the guitar and left it on the snare track. Meaning the reverb reacting from the snare hit would give the illusion of acting as reverb for the guitar. Late hear so I will try it tomorrow. I was just wondering theoretically.
Theoretically speaking, you're using reverbs to "put things back" in your soundstage. If you push everything back it's just as flat, isn't it? Just sounds washy.
I think the OP's premise is a little shaky. If I understand it correctly he's saying that the reverb he puts on the snare will create an overall reverb wash for the entire mix thereby negating the need for additional reverb on say a vocal or guitar track.
Reverb acts and sounds differently depending on several variables. A snare's percussive attack will highlight that reverb and push it up front in the mix but it also tends to follow the snare. The reverb present in between snare hits will not be highlighted - assuming there is a musical wash as part if the mix. Most vocals I record have reverb but u wouldn't really hear it unless u listened w headphones. The guitar would also have reverb but sparingly and not to the point of standing out in the mix. So my two cents: reverb can b applied to multiple instruments w/out washing out a mix if u apply it in the right increments. Applying reverb to a snare by itself would not, in my opinion be adequate reverb processing for the entire mix.
AJF Now: MacPro Tower OS 10.8 - PT2018- MBox Pro - MACKIE preamp for monitoring only - mostly WAVES PIs - a couple of AKG/Shure Mics - MAudio Key49 Up Next: Mac Mini M2, PT 2023.9, Focusrite Solo - I love this set up! It's faster than I could have hoped for. Then: ProTools 5-ish digi001 on a PC running Windows Millennium BD (before digital)-from Tascam 8-track to Neve 64 - ran live audio for Club 88 in LA (Decline of Western Civilization) and Stage East in N Hollywood "...this puts things into perspective...too much ****** perspective..." David St Hubbins and Nigel Tufnel standing over Elvis' grave. |
If you can, then you should be able to judge, whether the mix could do with a bit of reverb here or there, if not, then listen to the different tails and try again. |
Again - I know this was an elementary post but I had never taken the time to do this before. I took a snare track after end of song and recorded one hit with no room mics in the picture - bone dry panned hard right. Did the same with a Stratocaster on another track by hitting one not and muting it immediately after the pick hit the string panned hard left. Inserted same reverb on both tracks and panned the effect on each to the opposite side of the respective instruments. Soloed out the snare reverb alone and voila - it was in fact as everyone said, obviously a snare drum that created the effect that was coming through the speakers. Same with the Strat. Obviously I think to much but my little experiment has in fact made me think more critically about how I will approach the use of reverb when I start to mix. Thx for the replies.
2020 Mac Mini I7 3.2GHz, 36 GB Ram, Catalina, ProTools 2018.12.0 UAudio X6, Axiom Pro S49 MkII, Maschine MKIII. Last edited by mrgroovy; 07-12-2013 at 05:24 PM. |
But then you get into tricks people use to try to leave room for the various instruments to be heard, one of which is to time the snare verb so it's out in time for the next hit. This of course is totally unrealistic, since who says the concert hall changes size for every song according to tempo? Then there's putting some slap on the guitar, but no reverb, which can be enough for some people to feel like there's a room on it. Why does the ear accept a cavern on the snare, and a tight slap from the guitar like there's a brick wall perpendicular to the amplifier 15 feet away? This is where the art comes in, and good luck. Listen to every record ever made, emulate your favorites when you can. Take a break every once in a while.
HD Studio, PT2022.6, UA Apollo x6, 2018 MacBook Pro, 32 Gig, Big Sur |
Multiple Midi Instruments | eklektos | MIDI | 1 | 11-03-2008 01:40 PM |
Multiple virt. instruments | Benneedshelp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-22-2007 12:58 PM |
using multiple instruments on XPAND | CrAkD | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-06-2006 01:40 PM |
using multiple virtual instruments in PT 6.4 | Phate | MIDI | 0 | 08-04-2006 10:06 PM |
multiple outputs with NI instruments? | Detlef Brockmann | Pro Tools TDM Systems (Mac) | 0 | 09-19-2004 04:31 AM |
