Old 10-22-2010, 10:57 AM
mwconn@yahoo.com mwconn@yahoo.com is offline
Default Unable to reacquire hardware
Pro Tools is unable to reacquire hardware because it is in use by another application.
I can not adjust the buffer size.
I don't have any other applications on the computer and am not hooked up to the web. The system has been running fine for a year... up till now.
I am in Pro Tools 8, Digi 002 Rack into a Dell Dimension 4600 duo core with maxed out ram.
Thoughts?
Old 10-29-2011, 03:18 PM
Ang1970 Ang1970 is offline
Default Re: Unable to reacquire hardware
Did you ever find a solution to your problem? I recently was having the same error message.
Cheers,
Angelo Quaglia
Old 10-29-2011, 04:01 PM
Sparky1 Sparky1 is offline
Thoughts?
Maybe try the windows forum - this is the Mac side of things - you may have better success over there...
Sparky
Old 02-16-2019, 01:46 PM
boombopbop boombopbop is offline
I'm having this issue. 2/15/2019 system ran fine for over a year and then all of the sudden it started this... did anyone figure out what the issue is? thanks
Old 02-22-2019, 06:50 AM
If you are on Windows, go into Sound Properties and set Windows to use the on-board sound card as its "default playback device"(which leaves the interface alone so PT can use it)
Unable to reacquire hardware and DAE error 6117. Please help TheSmackPanda Pro Tools 10 2 06-16-2015 02:02 PM
Exiting playback engine! PT unable to reacquire hardware crizdee Pro Tools 10 1 12-17-2011 03:28 AM
"...unable To Reacquire Hardware..." Help, please!! Rooster777 Pro Tools M-Powered (Win) 2 02-27-2008 12:10 PM
unable to reacquire the hardware! "MDW" The cause crizdee Pro Tools TDM Systems (Mac) 4 01-23-2006 06:09 PM
Unable to reacquire hardware.... Mark Tandy Digidesign Hardware & Software 4 06-07-2001 03:55 PM
