  #61
Old 05-23-2019, 01:59 PM
larsongs larsongs is offline
Default Re: Using multiple versions of ProTools??
After market repair places can replace motherboards, if needed, likely from a donor machine. Or at that point just buy a used machine and move the other components over.
One of my favorite MacBook Pro was a 17" model. I loved that computer. Opened up and memory maxed out by me. It had the motherboard/GPU replaced under a recall program. Both CPU cooling fans replaced on separate occasions by me (don't use your computer in dirty wood working shops). The HDD replaced with a SDD by me. The screen replaced by me (just totally died one day). The SSD upgraded again by me.
Differentiate all this from my current MBP which I'd not want to open myself... and which now has a cursor key failing on the crappy butterfly keyboard and needs to get repaired.
At some point the increased power of new Macs will be so appealing or some new Pro Tools feature that needs some new macOS will be so appealing that you will migrate to a new Mac. And I expect that will happen before it becomes impossible to repair your current Mac Book Pro, just because they are so repairable. But I would hope you get several more years use out of it.
Good points. Thanks
  #62
Old 05-23-2019, 02:28 PM
If you haven't heard Apple extended the repair deal on those wonky keyboards so more you should be in luck with a warranty repair.
Any of the Apple 17 inch laptops were a breeze to repair if you had the right tools. There was so much room in them.
  #63
Old 05-23-2019, 02:40 PM
Yep, on it. Just need to find time.
  #64
Old 06-19-2019, 09:56 PM
My MBP SSD & new IMac upgrades & acquisitions got postponed a bit as I had a couple Graduations & a Wedding for my Kids & Nephew that set me back a Mac & some Cash...
I plan to do the SSD in the next couple weeks.. The IMac is a couple months away..
Anyhow, a Buddy of mine got a new IMac 27" Retina, I9 Processor, with 8 GB & 3 TB fusion Drive. He bought 2 - 32 GB Memory Cards from OWC. For a total of 72 GB RAM.. He says, he plans to get 2 more for a total of 128 GB RAM..
Is that doable? If so I will probably go that route as well... It will help to save $$$..
Thanks
Multiple versions of PT 11 - alternating on same system (OSX 10.9.5) stargazer macOS 16 12-31-2014 03:48 AM
Running multiple versions of Pro Tools Scintillaterich Windows 7 10-12-2012 01:30 PM
Multiple Computers/versions cymbaline Pro Tools M-Powered (Mac) 2 03-30-2009 04:24 PM
Installing Multiple PT versions reddbeard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-04-2007 07:07 PM
multiple versions of ProTools on one computer? KingTor Pro Tools TDM Systems (Mac) 4 09-15-2006 12:01 PM
