Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | S6
Old 08-16-2019, 10:02 AM
DAPG DAPG is offline
Default Fader Metering Bug (I think)
Hi Everyone,
I think I found a Fader Module software bug. I'm using the latest version of S6 software (19.7) and latest eucon and latest PT Ultimate (2019.6). Bug existed in the previous S6 version as well (19.5).
On whatever fader module is defined as a fader expansion zone, when the Fader EXP is disabled, the metering on the fader goes blank once you touch the fader. Metering comes back if you bank faders or nudge faders.
I can replicate this behavior on any of the four fader modules I have.
Here are the steps to re-create this behavior:
1.) Define a fader module as an Expand Fader zone.
2.) Use that fader module when the Exp Fader is disabled (make sure signal is on that channel)
3.) Any fader that you touch loses its metering until you bank faders or nudge faders, or after enable/disable exp fader.
Can anyone confirm that this can be replicated on your system?
Thanks!
Roy Machado
Dallas Audio Post
Old 08-16-2019, 10:57 AM
creativecontrol's Avatar
Default Re: Fader Metering Bug (I think)
Greetings,
I think we may need some more data. I can't reproduce that behavior here with a simple session. Here are my vitals:
S6 19.7.0.101
PT 2019.6
macOS 10.14.4
MacMini 2018
Please let us know if there are any other details that you can share to shed some additional light on the issue. Thanks!
Jeff
Jeff Komar
Old 08-19-2019, 09:32 AM
EddieJones's Avatar
This is known and down to be fixed in the next release.
Old 08-21-2019, 11:54 AM
Thanks for the confirmation. I'll look forward to a a fix. I appreciate your time in tracking it down.
Roy Machado
Dallas Audio Post
Old 08-23-2019, 10:50 AM
budster budster is offline
I have the same issues on 19.7 plus sources from DADman not showing up.
Pre Fader Metering Setting DonM Pro Tools 11 4 07-05-2013 08:28 AM
Pre-Fader Metering vs Post-Fader Metering teacherman Pro Tools TDM Systems (Mac) 3 01-29-2008 07:33 PM
Pre-Fader Metering problem Escape 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 02-18-2005 01:41 PM
Pre or Post fader Metering? Forrest77 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-20-2003 12:35 AM
Pre-Fader metering? pk_hat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 06-16-2002 03:30 PM
