External Hard Drive problems with Protools
Hi there,
Has anyone had any issues using G-Tech external firewire drives with Protools? I'm using two external G Drives, one with my sample library and another where I save sessions and all my audio. Recently it's been nothing but trouble. I'm talking spinning beach ball of death often for five minutes at a time. It's literally doubling the time all my recording sessions take as it's spinning for approximately 50% of the time. The activity monitor says Protools is only using 15% of CPU power so I'm assuming it's the g drive. And occasionally, when this happens, the mac will just stop reading the audio drive and I'll get a pop up box telling me I've disconnected the drive prematurely. Really killing me. |
Re: External Hard Drive problems with Protools
IIRC, G-Drives ship with a DVD that includes advice re troubleshooting. Have you looked at this?
Does the HD mount OK? Have you tried a different FW cable or socket (if you have one)? |
as Phil says u have to try others cables and connections...
BUT also do u have it on a HUB? is it conected alone? Is it happening when u are plugged on energy or on battery? |
The OS claiming the drive being unmounted could be a faulty cable or controller on either the drive or the logic board. If the drive unmounting happens immediately after a SWOD where the computer is trying to do something with this drive, then I would suspect drive corruption as noted above.
Have you applied all the standard systems optimizations? especially including disabling spotlight indexing on all these drives?
Darryl |
External Hard Drive Problems | Isaacx | Storage Subsystems | 8 | 09-01-2008 03:46 AM |
Problems with External USB Hard drive | sabbrodo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-10-2007 07:05 AM |
Problems with my external hard drive | sellinout | Storage Subsystems | 2 | 02-03-2007 05:00 PM |
external firewire hard drive problems | philippebruno | Pro Tools TDM Systems (Mac) | 4 | 01-30-2006 01:04 PM |
External Hard Drive problems | Ras Gabriel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 08-18-2005 06:48 AM |
