AAE error -9073
I am running Pro Tools 12.7.1 on windows 10. I am using a Dell Inspiron 16GB RAM 1T hard drive, with Intel 7 dual core.
It continues to tell me "can't get audio from the drive(s) fast enough. Your drive may be too show or fragmented, or firewire drive could be having trouble due to the firewire bandwith or CPU load. (AAE -9073)" This is a brand new computer with plenty of space. Any thing I can do? I can't playback any tracks without seeing this message. Really frustrated. |
Re: AAE error -9073
do you have a lot of audio track playing ?? are you using Disk Cache ?? more info please cheers john
Re: AAE error -9073
Hi as john says more info would be helpfull . A complete system report would be good .
Also are all windows 10 optimizations and tweaks done ? Sent from my SM-G930P using Tapatalk
Mac M1 Studio Ultra - Sonoma Beta OS Avid Carbon Interface Protools Ultimate |
Re: AAE error -9073
I have it set at the default setting now. Buffer - 512 samples, disk cache at normal. I watched a tutorial on YouTube, it suggested that I use a lower setting for tracking, and a higher setting for mixing. I've tried it both ways and I still get the same error. I even tried changing the I/O settings and it's the same error. At the most, I have ten tracks playing simultaneously. Just music tracks, I can't get to the vocals because it keeps stopping. thanks Sam |
Re: AAE error -9073
Hey Sam
The 9073 error message is a hard drive issue and comes on when your drive is too slow or filled up to the brim. How is your hard drive setup? Only one for both OS and recording to? If this is becomming a serious issue than i would get a secondary hard drive as suggested by Avid and use that for recording only from PT. Pro Tools NEED its own recording drive especially if you don't have a really fast SSD drive as OS drive so that is a problem and not much can be done except getting a dedicated recording hard drive, preferably a SSD but if money is tight get the best spenner drive you can. Need to be a minimum of 7200rpm and disc cache 64MB and 9ms seek time or better. The WDC Black 1-3 TB drives are super and many many members here use those with great success as do we.
Re: AAE error -9073
Plenty of space tells nothing about the performance requred for PT record/playback. You might have a system drive that has "plenty of space" but it is too slow for your session. Please buy a dedicated drive for your PT sessions, as is per manual.
Re: AAE error -9073
Re: AAE error -9073
On Windows especially, this doesn't work well trying to record to the system drive. Part of a correctly configured setup involves a 7200-rpm secondary hard drive specifically for recording and playback.
Re: AAE error -9073
lets wait for the OP to reply .. you guys are always helpful with PC issues where it is not my game .. cheers john
Re: AAE error -9073
In his original description, he said he has "a 1TB hard drive." Are you a betting man?
DAE 9073 Error (Disk too slow) Error | peytontodd | Windows | 8 | 08-21-2014 01:32 PM |
Error DAE cant get audio from drives fast enough -9073 error on BIG MIX SESSION | dairyman3833 | Pro Tools 10 | 4 | 06-26-2014 08:35 PM |
Another 9073 Error - Please help! | peytontodd | Pro Tools M-Powered (Win) | 2 | 11-22-2011 10:07 AM |
Error 9073 and Error Increase/Reduce H/W Size during playback Digi001 | Karma180 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-05-2011 07:46 PM |
adat loopback error#4 and error 9073 | uri | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-22-2003 11:19 AM |
