protools 12.8 win10 firewire problem
protools will not activate sound (sapphire 56 focusrite). focusrite software loads fine but protools will not run at start up help anyone?
Re: protools 12.8 win10 firewire problem
Make sure your Focusrite is not being used for system sounds.
Try holding down the N key while PT starts, which will force a playback engine refresh and should allow you to choose which sound device you want to use with PT. If that doesn't work, you may want to try re-installing your Focusrite drivers, making sure you are using the latest for your OS. If that doesn't work, try trashing your PT prefs. Beyond that, we'll most likely need some more information about your system and setup in order to help you through your issues. |
You might have to use the Legacy FireWire driver..
Details on how to do it here.. http://duc.avid.com/showthread.php?t=402340 |
Win10 Pro - Class Compliant Hardware Problem - Midi | YYR123 | General Discussion | 23 | 06-18-2021 10:33 AM |
Unsupported Audio Buffer Size Error ProTools 11 Win10 | thegrinch | Pro Tools 11 | 2 | 09-17-2017 09:26 AM |
HP z440 Win10 Aja Lhe plus Protools 12.5 Media Composer 8.5.2 | jveekeres | Windows | 1 | 05-21-2016 11:12 AM |
ProTools 12.1 on Win10 and UltraLite-mk3 Hybrid | handroid | Windows | 2 | 08-02-2015 04:20 PM |
Firewire-Protools "Check Disc Allocation" problem | GlowGirl | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-06-2005 01:05 AM |
