Old 04-09-2015, 05:29 PM
diogo_c diogo_c is offline
Default iLok activation errors on plugins (AAE-7504)
Hey everyone,
I'm getting a lot of the following ilok authorization errors when opening a session:
It's quite random and affects random plugins, making them inactive on a project. Even PT's stock plugins are affected by it sometimes. If I try to make them active I'll get a AAE-7504 error.
I've tried updating ilok software, tried the dongle on different ports, triple-checked power settings to make sure they're not set to turn off the usb ports, thrashed PT preferences and no luck so far. Anything else I should look for?
Regards!
PT 12.7.1 @ OSX 10.12.1
RME Babyface Pro - MC Control V1
Old 04-12-2015, 06:03 AM
Default Re: Ilok activation errors on plugins (AAE-7504)
No one?
Old 04-12-2015, 07:25 AM
jonathan jetter jonathan jetter is offline
i've been getting those errors sporadically on 11.2.1 and 11.3.
hasn't happened when opening a session, but rather when instantiating plugins in a session.
i've tried all the same things you have. nothing's solved it permanently.
closing + relaunching PT fixes it temporarily.
Old 04-12-2015, 09:37 AM
Ilok in a usb3 port?
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 04-12-2015, 06:49 PM
Not at the moment, but I've tried - same thing.
Old 04-13-2015, 07:05 AM
Benoni's Avatar
Benoni Benoni is offline
I've seen this happen with Media Composer but not Pro Tools. Haven't got to the bottom of it yet.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 01-06-2019, 07:43 PM
Hexman311 Hexman311 is offline
I know this is an old thread but I am really desperate and I'm wondering if diogo_c or anyone else ever found a solution to this issue.
Nearly every time I open a session with plugins, that same iLok error message pictured at the top of this thread comes up for each plugin it's about to make inactive. Sometimes it's just D-verb, sometimes it's several. (usually only happens with PT stock plugins) I have contacted iLok, uninstalled and reinstalled iLok's license manager, re-sync'd and even tried reinstalling PT but it nothing works.
What am I not doing here?! PLEASE HELP
Dell Precision m6700
Windows 7 pro 64 bit
PT 11.3.1
Focusrite 18i20
Old 01-07-2019, 06:06 AM
PT 11.3.1
Focusrite 18i20
I see you're on Windows and those machines have power savings measures turned on by default even for desktops. Go to Windows Control Panel Device Manager (IIRC) and turn off all power savings measure for the USB ports.
BTW if you want to find diogo c he's an administrator over on Gearslutz
Jack
QAPLA!
Old 01-07-2019, 01:57 PM
Musicman, thanks for the reply. I tried disabling the power saving measures on the USB ports but no luck. Maybe I'll reach out to diogo_c and see if he was able to resolve it.
Or maybe someone will have another suggestion on here.
Either way, thank you
Old 01-07-2019, 08:06 PM
Top Jimmy's Avatar
Go into the Services panel and start "Pace License Services". IIRC, this service is set to start manually when the presence of an iLok is detected. Sometimes that mechanism gets broken for some reason. Change the service to start automatically and it should solve your problem.
James Cadwallader
Upgraded to 12 and having Activation Errors amishsixstringer Pro Tools 12 15 11-23-2017 03:10 PM
iLok asking for activation - please help! jamiet Licensing & Accounts 9 10-03-2017 12:55 PM
PT HD 12.6: 3rd party plugins ask for activation or PT cannot see valid iLok license Novae Studios Pro Tools 12 4 10-15-2016 05:47 PM
Prompted for ilok Activation on plugins I have activated on ilok tmoneygetpaid macOS 1 12-04-2014 10:40 AM
iLok Activation Questions mickc Windows 4 02-17-2013 05:51 PM
