Soft Samplecell midi channel limit?
Dear Sirs:
Is there a way around the aparent 16 midi channel limit when using Soft Samplecell? (Other than having hardware Samplecells.) Thanks. BR |
Re: Soft Samplecell midi channel limit?
Just run another instantiation of SoftSamplecell and you'll have 32 channels. There's really no limit other than CPU power.
Kevan |
Thanks Kevin, but I don't quite follow.
Instantiate another direct connect plug on another channel? From what I understand, that would only allow you to access more audio streams, maxing out at 32, and wouldn't affect the available midi streams. Or do you mean launch another soft samplecell bank from within the app? Would each bank have it's own 'bank' of 16 midi channels? From my knowledge of Samplecell+ I would tend to think this wouldn't be the case, but I've been wrong before. Thanks, Bryan |
Okay, I tried both possibilities and neither gave me more midi channels. Somehow we need to get another soft samplecell icon to appear in the OMS setup.
Hmmmmm. Digi? |
Brent,
Is it possible to use 2 Soft SampleCell instantiations and thus get 128 voices, as long as your computer is powerful enough? If so, how would you do this. Thanks........
Mac Pro 3.5GHz 6-core (6.1 2015) Monterey 12.6.8 64 GB RAM 1 TB PCIe flash storage Pro Tools Ultimate HD 2023.6 HD Native Thunderbolt |
just to clarify...I'm curious about the MIDI channel limit, not the voice count (which I'm 99.9% certain is fixed at 64 max, from what the manuals say).
Soft SampleCell is limited to the following:
64 voices 16 MIDI Channels 16 audio outputs -In other words, it is not possible to have, say, two SampleCell Banks open simultaneously, for a total of 128 voices, 32 MIDI channels and 32 outputs. As a side: DirectConnect is limited to a maximum of 16 stereo (32 mono) audio streams Brent |
Soft SampleCell on seperate Mac, no midi... | tuchel | Pro Tools TDM Systems (Mac) | 2 | 04-05-2005 07:40 PM |
OMS 16 Midi channel limit? | Dean Bohana | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-29-2004 09:34 AM |
Soft-Samplecell: can't select it in midi-track. | Allan Speers | Pro Tools TDM Systems (Mac) | 3 | 08-03-2002 02:25 AM |
Soft SampleCell not compatible with SampleCell 2 | P BUCKLE | Digidesign Hardware & Software | 13 | 06-08-2001 11:01 AM |
Soft SampleCell not compatible with SampleCell 2 | P BUCKLE | Pro Tools TDM Systems (Mac) | 11 | 06-06-2001 10:24 AM |
