Old 08-19-2004, 05:30 AM
kcurry kcurry is offline
Default Re: 002 compared to Command8
It DOES record automation: you just can't set the automation mode or change what you want to automate with it. For example, you can't use the C8 to change a track from auto read to auto write, nor could you set up a control on a plug-in to be automated. However, once you have done this with the mouse, you can certainly record automation for any parameter using the controls on the C8...
Old 10-19-2004, 07:25 PM
bigears bigears is offline
so are you saying that the digi002faders version could do all of this for you?
or are you talking about a more expensive bit of gear?
Old 01-10-2005, 01:36 AM
bluesna bluesna is offline
I have a Digi 001 and calling Digi tomorrow to trade in and up (unfortunately , not an HD)
I also am deciding 002R and Command 8 or Digi 002.
I probably will go with the Digi 002factory and a Digital Console. Either Yamaha , Tascam or Spirit so I can mix out of the box and use channel onboard gates/comps /fx along with rtas. I mix often in stems. i also have a Spirit analog console M8 which has a digital out. A REALLY KILLER little console for the money. Sweet EQ , DI's on every chanel , spdif out and the pres are pretty good.
I'm trying to figure out the best way to get the BEST POSSIBLE signalinto and out of the Digi002. Considering Appogee Rosetta , mini me, mini dac , etc
I see that many of you are concerned with talk back.
One of my friends has a killer 1 rack unit , I forget what it is that has talk back , several stereo pairs and was pretty costly , i think around $850.00 and works and sounds great.
I , on the other hand didn't have that much cash so i purchased the Samson C-Control. GREAT LITTLE UNIT !!!!!!
Not as transpaent as my firends but for the miney ....
It gives you several input option and you can switch between 2 sets of powered monitors and turn your sub woofer on or off , also mono , dim , mute and TALKBACK / talk to cue. A REAL HANY LITTLE BOX .... A MUST HAVE FOR ProTools.
see ya
frank
http://www.upinthenitemusic.com
rokalias
MDW V3.0 compared to V2... acacia Pro Tools TDM Systems (Mac) 3 09-29-2008 05:47 PM
10.4.2 as compared to 10.4.9 Muzoid Pro Tools TDM Systems (Mac) 0 05-29-2007 04:20 AM
PT LE COMPARED TO... mykhal c 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-10-2007 09:29 PM
002 compared to Command8 Jsalam112 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-27-2004 04:35 AM
888 compared to 192 sukks2bu Pro Tools TDM Systems (Mac) 10 04-01-2004 01:24 PM
