Go Back   Avid Pro Audio Community > Pro Mixing > System 5
Old 05-20-2018, 01:52 PM
shauli shauli is offline
Default win 10 april 2018 update / mcpro drop
hi,
after updating windows 10 to the latest April 2018 update, MCpro keep dropping out of the net work.
anyone can confirm that is not a local problem?
Eddie, any solutions to try?
Thanks.
SD.
Old 05-31-2018, 09:39 AM
EddieJones's Avatar
Default Re: win 10 april 2018 update / mcpro drop
I haven't heard this. Did you try uninstalling and reinstalling EUCON ?
Old 06-07-2018, 09:19 AM
I found that the issue is having 2 Ethernet connections. PC Win 10, I have one Ethernet connection going to the sys5 router (no internet, only local network) and another Ethernet connection that is going to a local network switch that have internet access.
As soon as I connect the Ethernet connection that open to the local/internet, the MCpro will drop out and I lose the connection between the mcpro and the computer.
Same thing on 2 different computers.
Any suggestions?
Old 06-09-2018, 08:31 PM
EddieJones's Avatar
Firstly don't connect the second Ethernet whilst the EUCOn software is running, it doesn't like network changes, run EUCOn after.
I suspect its to do with either having 2 default routes or the network priority order. Try a fixed IP address for the EUCON network first.
Any Win 10 April Update Issues? taylor4814 Windows 2 05-04-2018 10:25 AM
structure free library missing since 2018 update mbeswick Pro Tools 2018 3 03-02-2018 05:46 AM
eLicenser update Version 6.7.1.8145 – released April 22, 2014 unkJE Virtual Instruments 0 04-25-2014 10:27 PM
April 12th new 10.6.3 v1.1 combo update onepercentfree 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-13-2010 12:36 PM
PT LE 6.4 Update approximately April 19 Tomy DeClerque 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-19-2004 05:21 PM
