Old 05-28-2019, 05:59 AM
garret garret is offline
Default Re: Sync HD losing dropping lock
Originally Posted by mgoorevich View Post
You might want to check if your Sync HD is well cooled as its very sensitive to higher temperature.
Does this happens at the morning when the unit is cold?
I had the same problem with my Sync HD in conditionered machine room until I made some room above and beneath of Sync HD in order to be well ventilated.
Yep. Had the exact same issue with overheating the sync HD. Had to take it out of the rack and have it sit on its own and the problem went away.
IMDB
Old 05-28-2019, 05:06 PM
kkfaudio kkfaudio is online now
Finally back in that room with some time today.
Unfortunately I was unsuccessful today. I made sure things were terminated properly and no change.
I’m wondering about heat. I removed the unit from a rack soon after buying it, and it was sitting alone in a corner because it definitely showed overheating symptoms.
About 6 months ago I wanted to tidy things up, and put it in an unenclosed table top 3 unit rack. My omni is in the bottom, the sync HD in the top, so a full space between the 2 and open to the room..
It does feel a bit warmer than ideal at the moment, mostly the heat from the omni. I really thought it would be cool enough, but maybe not.
I’ll try putting it back where it was, to see if that’s the problem. I don’t remember having as many dropouts before it’s most recent spot, so the heat could conceivably be the culprit.
Thanks for your help - it’s much appreciated.
Kevin Ferrier
Audio & Sound Design
www.trianglepost.com
HTML code is On
Dropping sync after 6+ hours lucienpalmer Post - Surround - Video 5 11-07-2015 07:10 PM
HD system dropping out of sync decibelmel Pro Tools TDM Systems (Mac) 0 10-25-2003 01:14 AM
Pro Tools dropping out of sync ever since HD uno1234 Pro Tools TDM Systems (Mac) 26 05-31-2002 06:50 PM
my mac dropping into number lock in pt tomcat Pro Tools TDM Systems (Mac) 1 10-14-2001 04:09 PM
PT and USD dropping out of sync!? Boom Chic Pro Tools TDM Systems (Mac) 5 02-12-2001 09:10 AM
