C24 offline... help!
bought this unit in 09 and it has worked flawlessly, woke up one morning last week and it showed "offline" I don't have a clue how to get it back online. I can't find anything in the manual that talks about such a problem. Has anybody seen this before? help!
I'm working on a Mac pro 10.6 with HD system |
What kind of troubleshooting did you do?
Does ProTools see it in the periferal window? Did you tried another ethernet cable? Did you trashed the prefs? JC |
Re: C24 offline... help!
I am now at home and won't be back at the studio until 5pm this eve. I will try your options
I only checked the cable. I noticed that once it was yellow and the other time it was green(the light at the cable input) what is the the right color? I didn't know if I should trash the preferences or not? I am sorry but I don't really know how to look for it in the periferal window I will try these options when I am there today and let you know. Thanks so much for you quick rescue. Al, |
I went into set up>peripherals> ethernet controller. I only saw a box there that to see a box called enable(it was not checked) I checked it, closed computer, then opened again. The box was unchecked again. Did not see C24 nowhere in there though. I thought I was supposed to see it.
C24 is offline | Molchoon | ICON & C|24 | 5 | 07-28-2010 05:10 AM |
003 goes offline | Glide | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 03-11-2010 08:41 AM |
PT goes offline? | lode | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-05-2007 03:45 AM |
C8 OFFLINE in LE7 on XP, but OK in LE6.4 | CHD | ProControl, Control|24, Command|8 | 0 | 03-28-2007 05:53 PM |
why do i get offline | klownprince7 | ProControl, Control|24, Command|8 | 4 | 11-17-2004 07:27 AM |
