Installing plug ins
I would like to install plug-ins for Pro tools 8, can some one please explain to me how I do this? Windows 7 Thank you.
Re: Installing plug ins
Hi
we need to know more what plugins you are looking to install as there are a sea of them out there Whats your computer and what setup do you have? RAM, Hardrives etc? Do you have any plugins you want and if so, what are they? Best Regards Christopher
If I recall, the Bomb Factory Plugins that come bundled with Pro Tools get installed automatically when PT is installed. Go to C:\Program Files\Common Files\Digidesign\DAE\Plug-ins and you should see a Plug-ins and Plug-ins (Unused) folders.
All of your installed plug-ins should be in the Plug-ins folder. If for some reason they are in the unused folder, move them over to the Plug-ins folder
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit. |
64bit windows 7 i5 4thgen 8gigs system Ram Gtx760 graphics card Two HDD. I don't have any specific name for a plug in that I like, but I would want to download some preamp or amplifier for my guitar. I dowoaded a few and put them in the Plug-ins folder, but they didn't show up when I started a new session in PRo tools. I am using PRO tools 8 SE. Thanks for help. |
Hi
When you say you "put them" in the plugin folder, did you download a plugin and install it where the plugin wants or did you just put it there yourself? I honestly don't know how PT8 LE works but you need to use RTAS format so you need to download and install the RTAS version of the plugins ypu wanna use. the installer for the plugins should install them where they need to be. We always download to the desktop and run the installer from there. Can you post how you installed the plugin you mentioned and what it is called aswell please Best Christopher
I downloaded the plugin and then manually put them in the Plug in folder. The plug-in that I downloaded is called "Antares Auto-tune AAX", I got it from "http://www.pro-tools-expert.com/free-pro-tools-plug-ins/". I don't specifically want to use an Auto tune, I just downloaded it to practice installing plug-ins. All the plugins that came pre installed are all DPM, RSR file format. I could'nt find any DPM or RSR file format plug ins. Thanks for help.
If you have PT8 LE AAX versions will not work as those versions are for PT10 AAX32 and PT11 AAX64 bit.
You need to download the correct plugins and versions of those plugins in order to work with your PT version. I never heard of RSR versions but if you want to have working plugins in PT8 you need RTAS versions and nothing else. .dpm is RTAS and the Plugins you would look for are called RTAS when you look at websites. None of the plugins should be "manually" put into folders, you need to download and unpack and install and the plugins will be deposited in their respective folders. We have never manually put anything in the plugin folders and neither should you if not asked to do so while installing, Christopher
Ok, I'll look for RTAS plugins and when I download them they will automatically go into the plugins folder? I'll give it a shot. Thanks |
Hi
Yes they will automatically install into the correct folder and no manual labour needed Best Cheistopher
I have another thread going asking if there is a guitar tuner in Pro tools 8 Se. One member posted that pro tools SE does not support Plugins. Maybe this is my problem?
Installing Plug-ins with 10.3.6 and 11 | Guitarman002 | Pro Tools 11 | 5 | 07-13-2013 02:38 AM |
Un-installing plug ins | Psychonaut4 | macOS | 1 | 04-15-2012 08:31 PM |
Installing plug-ins... Help! | yoodooright | Pro Tools M-Powered (Mac) | 4 | 07-13-2010 08:40 PM |
Installing a Plug-In? | Ryan H | VENUE Live Sound Systems | 2 | 03-12-2009 06:07 AM |
installing and using a plug in HELP! | seedsofvengeance | Pro Tools TDM Systems (Mac) | 7 | 06-09-2007 09:20 AM |
