Old 05-31-2011, 05:59 PM
Floz313 Floz313 is offline
Default How to Record multiple tracks in pro tools?
ok when i first open pro tools to record it works fine. but then when i add another track AUDIO 2.. OR AUDIO 3 ETC.. those do not want to record.. and only AUDIO 1 records?? thanks
Old 05-31-2011, 06:07 PM
Craig F Craig F is offline
Default Re: How to Record multiple tracks in pro tools?
input/output routing comes to mind
Thank you,
Craig
Old 05-31-2011, 08:04 PM
If you only work solo and only need to record a single input at any one time, you can go to the IO setup page>Input tab and delete the other input paths(so input 1 is the only available input and will ALWAYS be selected by default). You should spend some time with the manual(and youtube) and become familiar with the IO setup window. You can customize it to make your work flow smoother and faster
Old 06-01-2011, 08:04 AM
spidey01 spidey01 is offline
Also it's a good idea to name your tracks accordingly, ex. Bass, Guitar, Vocal, it will make things much easier for you.
Old 06-01-2011, 08:14 AM
Amen to that. A little detail work up front makes for a smooth project. You could also build a template session that has everything you usually need, like all tracks with names and input settings done, a few AUX tracks with your usual reverbs, a click track, and even the basic plugins you use the most. Add all this to a new session and choose File>Save as Template, and you can be into each new project fast and easy
Old 06-01-2011, 12:06 PM
thanks guys i really appreciate it
Record enabling multiple tracks joshfrog94 Pro Tools 9 2 11-14-2010 12:33 PM
How To Enable Record On multiple tracks jdsmooth615 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-05-2010 10:35 AM
Latency when record multiple tracks! audioplace estudios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-05-2009 05:11 AM
midi record on multiple tracks tommykartune 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-18-2007 06:07 PM
record multiple tracks in midi keggie1 MIDI 2 12-31-2004 11:25 AM
