Old 01-29-2019, 08:40 PM
feakerboo feakerboo is offline
Default Attention/Selected Track not working on dock
Can anybody re-produce this:
I have all my S3 faders as VCAs and use my Dock as an attention fader. The dock attention fader works fine till I spill one of my VCAs on the S3. After that, the Dock will ONLY allow me to attention VCAs. If I select an audio track in the edit window or attention an audio track via the S3, it ignores that selection and reverts to the last selected VCA. I can select VCAs from the edit window and they will switch but I no longer have access to my audio tracks until I restart Eucon.
I'm not sure when this began but I'm running the newest version of Eucon and I have updated all my firmware to the latest versions as well the latest protools version.
PT: Ultimate 18.12
Mac Pro Trashcan: 12core, 64GB Ram
Sonnet Pro: HDX3
Mac OS: 10.12.6
Thanks!
Brad e
Partial Credits
Old 01-30-2019, 12:31 AM
BrianGasacao's Avatar
BrianGasacao BrianGasacao is offline
Default Re: Attention/Selected Track not working on dock
Do you have the option 'Attention on Select Button Press' enabled in your EuControl Preferences?
Old 01-30-2019, 06:49 AM
Sorry just went through my EuControl Settings prefs (I'm on 18.3) and I don't see this option. Where can I located it?
Brad e
Partial Credits
Old 01-30-2019, 09:47 AM
I searched the Eucon Documents and was unable to find it there either. The odd thing is that the ipad app seams to be following the attention commands just fine but the dock won't
Brad e
Partial Credits
Old 01-30-2019, 02:22 PM
Hey Brad, sorry for the confusion. I mistook the issue you were seeing with something from our beta testers. The option I mentioned is not in 18.3 but rather our next release.
In regards, to the issue you're seeing. I got my system configured to match yours and this is by design. If there is a spill active on your surface, we don't allow the Dock Fader to be overtaken by a track type other than the same. Since it's a VCA master and the VCA master is required to perform an unspill the tracks (double pressing 'Select' button), this is why an audio track will not be attentioned. You will need to unspill the slaves to be able to attention other audio tracks to the Dock fader.
Old 01-30-2019, 02:27 PM
After I have unspilled, The dock will only allow me to attention VCA faders, I can no longer attention Audio tracks.
Brad e
Partial Credits
Old 01-30-2019, 02:36 PM
Actually more info, the way I have always been able to work in the past is this: rather than unspill, I select my master layout using the "A" softkey on the left of the S3 which puts the spill back away. Now it seems you have to manually unspill using the select key on the Dock or you are locked to attentioning only VCA keys.
The way this is designed leads to a bunch of confusion because now if I'm drilling down in a spill and select a member track, that track is on the ipad and the knobs on the dock control the ipad app but the mute, solo, and fader on the dock control the VCA.
It seams like it would just make more sense to let me to attention whatever I want so that it's less confusing.
Brad e
Partial Credits
Old 01-30-2019, 07:10 PM
EddieJones's Avatar
EddieJones EddieJones is online now
I'll take a look at this with Brian on Tuesday when I'm with him in our Studio. Eddie
Old 02-06-2019, 01:31 PM
Any word on this. The more I dig into it the weirder it seams. The dock's automation keys follow the selection but the fader and Solo, Mute, Sel, Rec buttons don't.
Brad e
Partial Credits
Old 02-06-2019, 02:03 PM
EddieJones's Avatar
Sorry I am sick and haven't gone into the office. Can you send me screen grabs of the General and Preferences tabs in the meantime.
Auto-bank to selected track not working strangy Avid S1, S3, Dock and Control App 26 08-04-2020 10:48 PM
Dock Fader - Attention Problem spoons Avid S1, S3, Dock and Control App 6 05-15-2018 07:04 AM
EUcontrol 3.6 Auto-bank to selected track not working? bsteeve Artist Series 49 03-09-2018 09:27 AM
Track View Toggle selected track on Dock dalonso66 Avid S1, S3, Dock and Control App 10 01-16-2018 08:28 PM
Attention Selected Track Dan Smith Avid S4/S6 1 03-10-2015 06:11 PM
