#61
Re: Workaround for lack of side chain delay compensation
adding the time adjuster plugin for some reason has 4 samples minimum so you have to always go that extra step to minus that 4 from the total.. anyway..so i'm not using this.. for me.. the answer is to create a silent trigger track, i.e clone my kick or loop or whatever and set it to no output. If i need to put a latent plugin on the receiving track, before the sidechain receiving plugin, (after is of no consequence, and further bussing etc you can do all you like), i'll just copy that exact plugin straight to the ghost trigger track, but not have it do anything.. for example if a compressor or gate, set threshold to max and min and so on.. if an EQ, just leave flat, and so on.. the latency is always assured to be exactly what the receiving track is and match up in this case.Remove a plugin on the receiving track? change one? simple, copy it over to trigger track. SO easy. I tested this with rhythms and it's very precise.. and no need to nudge clips or any of that. I am surprised no one else mentioned this method so far. There is only one scenario where further work would be needed.. 1) You decide to put some latent plugins on the trigger track (ie the track sending the audio to the S/C plugin).. then you'd have to nudge the audio backwards on that track, and you might need to subtract the total of some plugins from others to get the correct figure. Solution? Don't use latent plugins on ghost trigger track.. I mean, really, what need would there be? and on the track being modulated by the S/C, after the S/C plugin itself, you can put any darn thing you like.. only before causes issues. my method makes sense especially for grid based music, cause if you move stuff around on the ghost/trigger track, you can leave everything on the grid. mirroring plugins is not hard. In fact, around 95% of aax plugins besides a few like ik multimedia, have the same latency when bypassed.. you can literally just copy plugins over and bypass. No need to create any extra faders etc.. and once again, your trigger audio is still all on grid as no nudging was needed.
- Intel 14900K/NzXt Kraken Elite/64GB Kingston DDR5 6000 mhz (32x2)/ Asus Pro Art Z790/Asus 4090/Win 11 Pro 23H2/UAD Apollo 8 x2 w TBolt 3 card u/g/UAD Twin X. |
#62
Also I've always tended to put the "pumper" as the last thing on the plug-in chain (so you don't end up e.g. compressing the pumped signal so much you end up losing the pump effect!) but I appreciate that might not actually be necessary in a lot of cases. Really though I'm just looking forward to the time when this whole pumping thing is considered old hat. I mean that Eric Prydz track must be getting on for 14 years old now.... |
#63
ahh i didn't check using one ghost track to sidechain a few different other tracks. Will do!
I actually don't do any of my "movement" or "pumping" effects via sidechain if i can help it, as i have plugins like vengeance multi band sidechain and even the little waves pumper that make things like that very easy. I use them for clearing space in the mix.... ducking the bass with the kick etc.. that sort of thing.. for actual mixing purposes... *sometimes* if i make up some really great rhythm, i might then use it to gate or compress a pad, rather than use a plugin. I am still angry about this, i have been disappointed before but never actually angry with avid.....i feel it's downright cruel what they have done. Even the most basic, utility mixing side chain of using the kick to duck the bass, is out of time unless you have only absolute zero latency plugins to do so! Basically your attack and release settings are pointless lol cause they will be having the latency added or subtracted on. I couldn't find one other daw on the mac that does not compensate sidechain latency./ .Congrats avid, you really are the only one! I have seen people leaving pro tools to go to cubase in droves.. i know at least 20 people myself just in the last few months.. just personal contacts.. can you imagine if everyone knew 20 people? And where i was the one that went TO pro tools, they all gave me grief for it lol. Don't avid get it? They need to compete ffs! I want my money's worth for my sub cost! And with HDX.. i can't find any info that clears up the sidechain info.. ok.. i know you have to use an aax dsp plugin for the sidechain to be latency compensated, but what happens if you happen to stick a uad plugin before the dsp plugin, or on the ghost track to say, sculpt it (say, a uad transient designer). Does that throw it out of sync too? Avid have a very good PDC engine. This is arbitrary for them to "enable" for native users, they are just being difficult. Whatever method they use to calculate aax dsp S/C latency, just adapt it for native plugins. They are using the same mixer delay counter! Anyway, my whole day has been wasted on this, i need to crash but i'll answer for you in the morrow, i won't forget. Cheers
#64
Also agree with you on the other points, and it really does seem crazy not to have delay compensation for side chaining. |
#65
Please vote this one up too, fellers.
If you want to get the best out of sidechaining in Fabfilter Pro-L 2, we're gonna need multichannel side chaining, in addition to it being delay compensated! http://protools.ideascale.com/a/dtd/...a-tab-comments |
#66
MacBook Pro: 16GB M1 Pro 8c Hackintosh: MacOS Catalina, i7 6700k, 32GB RAM, RX580 Pro Tools Studio, RME RayDAT PCIe http://www.liamgaughan.com |
#67
created a pad on xpand, put pumper on it at 100% wet. Did a real time bounce. Then did an offline commit.. identical. Sorry, can't reproduce here.
#68
I just found this thread. Very interesting!
And also a confirmation of what I'm seeing/hearing in the latest version of PT (2019.12): ADC, especially for side chaining, is still not working. I also see the various timing issues when using the Commit feature. What worries me is that you need a degree in higher math to perform these constant calculations / plugin management to keep all audio in time.. Is Avid even aware of these obvious flaws in Pro Tools? Also, I'm currently on HD Native. Would switching to an HDX card solve any or all of these problems? (not that I would want to invest in an HDX card at this time, but that's a different discussion) |
#69
I’m not sure if I am right about this, but if you have one track being used as the side chain trigger to multiple other tracks, then I think that track has to have no inserts on it. And the tracks the side chain compressors are on (let’s assume it’s all compressors) can’t have any plugins before them on the insert chain. Is this correct? If so, where this gets hard is for a reverb aux track that has multiple things feeding into it but also had a compressor at the end of the chain to duck the reverb with, say, a separate kick trigger. Do you just print the combined reverb audio and the stick a compressor on the printer track and throw a side chained compressor? I’m not sure if you can even use the commit feature to print out a reverb aux if multiple things are feeding into it. |
no side chain delay compensation for HD Native users | OliverH | Pro Tools 11 | 50 | 09-02-2017 02:36 PM |
Side chain delay compensation fixed in PT HD 12 using Native card? | OliverH | Pro Tools 12 | 5 | 05-18-2016 08:39 AM |
Delay Compensation using Side Chain | Oblivion777 | Pro Tools 10 | 4 | 10-11-2012 01:22 PM |
Delay comp and Side Chain Issue | jimmyzk | macOS | 2 | 10-01-2012 02:46 AM |
