dual channel memory
Heres a stupid question..... What is the correct way to install dual channel memory?
I have 4 slots for memory, they are Socket A dimm 0 and dimm 1, socket B dimm 0 and dimm 1. I orginally had 2 sticks of 512ram in both dimm 0, then I bought more memory (2x512) to add. For the dual channel memory to work correctly, do I put them in socket A or Dimm 0's?
PTLE 7 Digi002R, Intel P4 HT 3.0GHZ w/ 865 Chipset, 2GB (4x512)RAM PC3200, WinXP Home SP2, 160GB 7,200rpm, 74GB 10,000rpm |
Re: dual channel memory
I suggest you follow the manufacturers instructions for your particular motherboard. If you don't have a manual, 99% of the time it can be found online.
Yeah, thats obvious.
Its not listed in there on the correct way to run dual channel memory. Does it have to be in both DIMMs of socket A? or do I need to match the memory to both DIMM 0's of socket A and B?
I belive you put on in a and one in b.
What motherboard? Have you visited the manufacturers site? |
Dual versus single channel memory | mjslakeridge | Windows | 2 | 05-13-2013 04:49 PM |
Dual Channel RAM | KamilFX | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-20-2006 10:24 AM |
Memory for my G5 Dual 2.0 | Choral14 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-04-2006 01:30 PM |
What do u think of the UA 2-610 Dual Channel...? | Ralph K | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-17-2004 09:48 PM |
OT Which dual-channel mic-pre between $1k and $2k? | pkcraft | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 10-11-2003 08:25 AM |
