Old 01-19-2012, 04:35 PM
raddster raddster is offline
Default Instrument track picking up my microphone, but not my audio track.
Hey everyone, I am using a Mackie Onyx 1640i with my PT 9, and I've been trying to record via Microphone. When using an audio track, it does not pick up the microphone, but when I use an instrument track it does. When using the instrument track it does not record what is coming through the Mic. Anyone have any suggestions?
Help!
-Radd
Old 01-19-2012, 05:36 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Instrument track picking up my microphone, but not my audio track.
Instrument tracks are for hosting virtual instruments and recording MIDI. If you're using a mic, you need to record to an audio track. I would suggest reading the PT reference manual on how to record a basic audio track. You need to have your I/O setup properly and set the input/output correctly on the audio track. Also, make sure you have a good signal from the mic on your Onyx.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 01-19-2012, 10:26 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Default
Sent from EPIC 4G using Tapatalk On'eim...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 01-20-2012, 07:26 AM
YYR123's Avatar
YYR123 YYR123 is offline
+1 for Chris and Keybeets
Daniel
Old 01-20-2012, 08:43 AM
Help!
-Radd
Are you using a MONO AUDIO track(you should)? Have you set the track input to the correct input source?
Old 01-20-2012, 04:11 PM
Default
Love to help
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
[IMG] code is Off
Can't Mute or Change Volume on Audio Track and Instrument track FunkTools 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-10-2010 04:40 AM
Problem Converting Instrument Track to Audio Track Gorbies 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-02-2009 09:11 PM
bouncing from instrument track to audio track rolew Pro Tools M-Powered (Mac) 5 04-18-2009 02:01 AM
GOING LOONY From instrument track to audio track Paul Cavins 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-18-2007 04:47 PM
Problem with second audio track picking up 1st Lucideye Digidesign Hardware & Software 6 07-03-2004 01:27 AM
