Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 09-12-2015, 12:43 PM
DJ Hellfire DJ Hellfire is offline
Default Not enough Delay Compensation?
I have a 24/48 mix going. Using several UAD plugins and a few Waves LinMB. I have a vocal buss channel with 8343 samples of delay and it's showing in red. Why is Pro Tools 12 unable to compensate this channel? Some of the tracks I have going to this buss have a peak delay of 8158 samples. So I'm assuming this is happening because there is a combined delay of 16501 samples between the tracks and the buss? There is no feedback from the software indicating what the restriction is. Can anyone confirm?
www.HellfireBeats.com
UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61
Pro Tools 2021.12
Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2
16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1
27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15
Old 09-12-2015, 12:48 PM
Default Re: Not enough Delay Compensation?
Actually found it buried in the manual. 16383 samples is the max. Guess I'll whip out the old Time Adjuster.
Pro Tools 2021.12
Old 09-12-2015, 03:12 PM
Emcha_audio's Avatar
DJ, the maximum delay compensation is dependent on the sample rate of the session. If in 48khz you find that you do not have enough delay comp, try going for 88.2/96khz which will give you 32 767 delay comp.
Page 971 of th pro tools 12.1 reference book
I've also found this in the reference guide of pt 11 and pt 12.
Delay that Exceeds the Compensation Limit When the total delay on a track exceeds the total available amount of available Delay Compensation (selected in the Playback Engine dialog), no Delay Compensation is applied on that track. Any audio on that track will no longer be properly time-aligned and will be out of phase. Both the Delay indicator and Track Compensation indicator turn red to show that the track delay exceeds the Delay Compensation limit. The maximum available Delay Compensation is applied to all other tracks. However, you can manually compensate for delay on tracks that exceed the Delay Compensation limit.
Manny.
Wave-T.com
Old 09-12-2015, 05:37 PM
Thanks! Wouldn't be able to go higher in sample rate as my UAD DSP would max out. I moved a few things around and got it back in the green. Thanks!
Pro Tools 2021.12
Old 09-12-2015, 09:53 PM
Sure thing!
Manny.
Wave-T.com
Old 12-07-2015, 01:26 PM
blastula blastula is offline
wouldnt doubling the sample rate cut the delay comp limit in half, not double it?
Old 03-28-2020, 02:32 PM
DorianBloom DorianBloom is offline
Do all DAWs have this limit on delay compensation? I could swear Reaper has no limit?
Old 01-18-2021, 05:16 PM
TuckerMix TuckerMix is offline
Only protools has this limit. Nuendo, Cubase, Logic, have no limit, many DAWs therefore don't even expose compensation to the user at all! You just don't have to deal with it.
This is a big mystery why Avid keeps this limit... PDC is just simple math, what computers do best. There is no reason why there has to be a limit... unless there is some archaic technical reason avid doesn't fix this in their code... either way, a clear pain in the ass.
I'm sure knowing avid there is some financial benefit to leave the limit there ;-) ...I hear another upsell coming!
Old 01-18-2021, 08:30 PM
JFreak's Avatar
JFreak JFreak is offline
That archaic technical reason is called DSP, and Avid simply has chosen to keep same limit with Native systems.
Janne
help fixing plugin delay and delay compensation disaster prestonhavill macOS 14 12-24-2014 03:35 PM
Delay compensation with backline delay chuck goodwin VENUE Live Sound Systems 3 08-09-2013 07:54 AM
Pro Tools 9 Delay and Delay Compensation on Aux Tracks and Bussing CNSound macOS 1 01-27-2012 11:10 AM
Delay compensation- choice of 'Medium delay'? dtmprod Pro Tools TDM Systems (Mac) 2 05-05-2010 11:00 PM
Delay Compensation - Delay Monitoring when REC Howardk Pro Tools TDM Systems (Mac) 2 06-18-2006 08:59 PM
