Old 12-26-2016, 07:05 AM
zakhilla zakhilla is offline
Default total newbie
hi all
i have just finished building my studio
i have a mac pro desktop computer
i am looking to get the whole pro tools package
i have used old versions of pro tools and logic
the first thing is apart from the pro tools specific apple keyboard what is the whole pro tools package? is it all soft ware? or is there hardware too? can they be bought separately?
are there any outlets in the uk? is it best to buy online? who is the most economic?
do i really need the latest? if i don't get the latest will there be crash or bug problems?
Old 12-26-2016, 07:58 AM
Wizzoboy's Avatar
Wizzoboy Wizzoboy is offline
Default Re: total newbie
I think you are approaching this the wrong way. Have you identified exactly what you will be using PT for? This will dictate what level of PT you need. HD, HDX, or native. What about control surfaces? You do not need a PT specific keyboard for instance if you learn the shortcuts. Yes, everything is available in the UK. Also check your budget. You can go from around £600.00 to several thousand depending on what you choose. But first I suggest you do some research. All the systems and software information is on the Avid website.
Dell Precision 490 Workstation, dual 4 core 5355 Xeon, 16gb Samsung DDR2 ECC Ram - Windows 7 Ultimate - Nvidia GTX 650 - 3 x Internal WD Blacks - PT 2018.3 - Digi 002R - Original Mackie HUI - 3 screens - JBL Monitoring.
Dell XPS 8700 i7-4790 - 24gb RAM - Windows 10 - Nvidia GTX 1060 6GB with Studio driver 546.01 - 2 x Internal Samsung 860 EVO SSDs, and MSATA card - Davinci Resolve Studio 18.6.4 - 3 screens - Blackmagic Speed Editor - MK1 Presonus Faderport - Canon C100 mk2 - Atomos Ninja 2 - Zoom H2n
Old 12-26-2016, 08:40 AM
Yes exactly what are you planning on doing? What sort of recording, VI composition, etc. etc.
What interface(s) are you planning on using? You got things like monitors, monitor controllers, control surfaces already?
To expand on the above... you can spend tens of thousands on a Pro Tools HD Digilink system (hardware and software). Asking the questions you are asking with no clear info about what you need/are doing is pointless.
Old 12-27-2016, 05:41 AM
hi ok i have a large album to edit mix and master
13 songs
some have 100 plus tracks
after this i will be recording editing mixing and mastering new albums
i have the os x El Capitan version 10.11.6
its a quad core 12 GB
i have used protools on another computer and almost finished the album when some guy came in and deleted all the work
i need to get back to it
Old 12-27-2016, 09:17 PM
When you use 100 tracks, are they audio tracks or midi (virtual instrument) tracks? How many simultaneous tracks do you record at a time? Regular vanilla Protools can handle up to 128 tracks while Protools HD can handle up to 768 (at 48KHz)/384(at 96KHz)/128 (at 198KHz). The number of analogue and digital inputs and outputs depends on your interface, but vanilla Protools maxes out at 32 inputs and Protools HD maxes out at 192 inputs. I hope that points you in the general direction when deciding what you need.
Oh, one more thing. Going forward, make sure you backup your data to a separate drive...and then backup again to another separate drive. Nothing is backed up until it is backed up twice. That way if someone deletes the data off the system, you can restore the data from the backup drives. You've learned the hard way about this lesson. It is probably the most important lesson. Sometimes you capture magic in a performance while tracking and it never happens again. You don't want to lose that take.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 12-28-2016, 03:15 AM
jre3132 jre3132 is offline
Also, I would recommend an off site backup. Whether that is you taking a backup hard drive with you as you leave or some type of cloud. I learned that when there was a fire in the building and my only copy of everything I had was inside.
Mac Pro 3.7 Quad Core Intel
Mac OS X 10.13.2
PT Ultimate HDX 2019.10
64GB RAM
HDX I/O 16x16 Analog
HDX I/O 8x8x8
Old 12-28-2016, 11:02 AM
The Weed's Avatar
The Weed The Weed is offline
And further to backups of data, images or clones of working system drives too.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 01-14-2017, 07:26 AM
thanks all yes i have a hard drive with original tracks on it
unfortunately the edit sessions were deleted from here so I'm starting from scratch
I'm going to select the tracks i want from the many takes so the track number will be less
I'm talking midi tracks (each instruments) when i get to edit i will separate the tracks (complete songs) and edit them separately
so protools hd sounds like the way forward,
where should i buy the complete package from?
and what sort of price am i looking at??
Old 01-14-2017, 07:39 AM
it is not clear
i look at some that say i need a card to run protools hd
some say i can get a student edition
some are 600 quid others are 2500
sorry to pester you guys but I'm getting confused
Old 01-14-2017, 08:23 AM
Wizzoboy's Avatar
Pro Tools HD software £2278.80. Non HD £550.80. For PT HD you will need an HD interface. The Avid Omni is around £2000.00. HDX is considerably more. For non HD there is a wide choice of interfaces from £200.00 upwards depending on number of inputs and outputs. One of the main dealers is HHB based in London. Or you can buy the software from the Avid store. As you are getting confused I suggest you do a lot more research to establish exactly what your requirements are. Are you sure that PT is the right software for you? You can also use the forum search function for information.
This is HHBs website.
http://www.hhb.co.uk
Total newbie to surround and a lot of questions soundworx Tips & Tricks 1 07-10-2007 02:33 PM
Anyone care to help a total newbie? T57Strat Pro Tools M-Powered (Win) 2 03-16-2007 10:26 AM
HELP! Total Newbie... :) GoofyDawg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 01-11-2007 04:57 PM
Total and Utter Newbie! Help! matt_sefton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-19-2005 10:43 AM
Total Newbie HELP, please point me the right way.. zeropointone General Discussion 8 06-29-2004 02:36 AM
