new ver 19.12.0.28 possible bug
Soft keys on Avid Control show up on ipad but not on Artist Control. They are either blank or grey and periodically appear but never in colour. The hardware buttons still work on the Artist control so when I hit a button it will select the proper soft key in the app. when i move to another user page hardware buttons on the Artist Control don't work anymore. very odd.
I like what i see however. Needs some tweaks.
Cory Rizos, CAS Re-recording Mixer/Sound Designer Montreal, Quebec http://www.imdb.com/name/nm0007185/ coryrizos.com |
Re: new ver 19.12.0.28 possible bug
This is what I see now. Look at the iPad soft keys and the Artist control.. it's all messed up
Sent from my SM-N950W using Tapatalk
From Page 27 of the new release guide with Artist Control
The Control app can be used simultaneously with an Artist Control, and they will share Soft Key assignments. However, you should only use the Soft Keys from one or the other media controller. Do not use Soft Keys from the Control app, then from Artist Control, and so on; choose one of the two controllers as your Soft Key controller. http://resources.avid.com/SupportFil...ide_v19.12.pdf I don't know if that's what you're seeing, but it might be related. |
I'm also seeing this bug on artist control, without an ipad. No softkeys. Sometimes, when you press them, they are reappearing, but without colors and are hidden again, when you change pages. macOS 10.12.6, PT 2019.10, Eucon 19.12.0.71
PT HDN 2024.3, OMNI, SYNC HD, Dock, 2xS1, PT Control, MacPro 5,1 12core 48GB, OSX 12.7.4, BM Decklink Extreme 3D ------------ mars13.de |
Reproduced in house will fix ASAP
Awsome !
Check out other pages as well. When I switch between pages of softkeays the hardware keys dont when work. I reverted to an older backup so I could continue working . Sent from my SM-N950W using Tapatalk
