Old 01-02-2014, 04:25 PM
JCBigler's Avatar
JCBigler JCBigler is offline
Default Sends on faders
I think sends on faders would be a cool and very useful feature for Protools. Anyone else?
Justice C. Bigler
www.justicebigler.com
Lenovo P50: quad-core i7-6820hq, 64GB, 2TB SSD, Win 10 Pro / Protools Ultimate 2023.6 / HD|Native-TB
2018 MacBook Pro: six-core i9, 32GB, 1TB, Monterey / Protools Studio 2023.6, / DVS / DAR, L-ISA Studio
Home/mobile: Focusrite Red 8Pre+HD32R / Clarett 4Pre
Road/hotel: Roland OctaCaputre / Apogee One
Old 01-02-2014, 04:29 PM
PMF Media PMF Media is offline
Default Re: Sends on faders
Um... not sure what you mean, but there are already 2 banks of 5 sends on every fader just waiting to be assigned.
Old 01-02-2014, 04:48 PM
JCBigler's Avatar
Oh, you mean those tiny little 1.5cm tall faders in the sends assignments section of the mix window?
Not nearly as cool or useful as being able to select a send and have that mix display on the main fader bank.
Sends on Faders mode explained...skip to 1:55
http://www.youtube.com/watch?feature...UjxjYre0#t=117
Justice C. Bigler
Old 01-02-2014, 05:00 PM
Craig F Craig F is offline
So you want a Fader Flip on the Mix Window?
Thank you,
Craig
Old 01-02-2014, 05:34 PM
I like the idea. Especially since the 003 is useless with this due to Avid's poor implementation(when you go to fader flip, the track names no longer show). Its pretty tough to make gentle/subtle adjustments as it is, so a flip option, or a tall send option could be quite handy
Old 01-02-2014, 05:36 PM
JCBigler's Avatar
Ehhh....Fader flip would work...as long as the main faders for each mix send are all assigned to the main fader bank. I want to be able to adjust the send level on every channel going to the same send at the same time, not just one channel at a time.
I guess it's my much more thorough experience running live sound that has me thinking this way.
Justice C. Bigler
Old 01-02-2014, 06:05 PM
Fader Flip on the ICONs flips a row of knobs down to the faders do you can do the Cue mix for A send, then B send, ext
Thank you,
Craig
Old 01-03-2014, 06:26 AM
nigelpry's Avatar
nigelpry nigelpry is offline
I can see some value in a flip fader option in PT software itself, it could be better in some cases than having to open up lots of individual long send faders that we can do already.
The main limitation is that you would have to be rigorous (aren't we all?) in dedicating a specific send slot on all channels to send to the same bus. I've seen many sessions where sends to a specific bus are spread across various send slots.
It could be very confusing if you used a flip fader option in the software and what you got on the long faders were actually sends to a variety of different busses. There would have to be an update of the track output selector to show the fader is a send, and to show which bus it is being sent to.
In fact, you could quickly end up with utter chaos if you didn't keep an keen eye on exactly what send routing each longer fader was actually currently controlling.
Mac Pro 2009 with 2010 firmware, 12-Core 3.46ghz, 64gb RAM & working Thunderbolt, OS 10.14.6 and Windows 10
iMac 2012 27", 3.4ghz i7, 32gb RAM OS 10.14.6
Digi 003 Console for control surface only, Focusrite OctopreLE and MOTU Traveler for extra analog-ADAT conversion, UAD Apollo Quad Silver with Thunderbolt card, Apollo x4 and pci-e Octo, Adam A77X monitors.
Pro Tools 2022.4, Media Composer 8.9, Sibelius 8.7, Cubase Pro 11, Wavelab Pro 11, Logic Pro X 10.5.1, Mainstage 3.
Various apps, soft synths, FX plugins.
Plenty of hardware synths, rack gear, microphones etc.
And then there's the studio ;-)
Old 01-03-2014, 12:28 PM
JCBigler's Avatar
Although I always assign the same sends to the the same send slots, I don't think it would matter since each mix send is still the same mix send no matter where it is instantiated in the send slot assignments...I.e. bus 1 is always bus 1 even if it is in slot 1 on channel 1 and slot 7 on channel 2.
The sends on faders mode would apply to the mix sends themselves, not the send slot assignments.
Justice C. Bigler
Old 01-03-2014, 04:16 PM
nigelpry's Avatar
Ok I understand, but that would not be a simple fader flip job, it is more complex.
Existing fader flip functionality on digi/avid control surfaces (well Control 24, C|24 and 003 anyway, which are the ones I've used) would flip a specific send slot volume onto the fader, while putting the channel strip volume onto the rotary encoder above, which normally does pan or a specific send slot's volume. So with this method you select what the rotary knob controls, then flip that parameter onto the faders.
Your suggestion seems more complex. If it was going to be implemented you might as well do it so any parameter can be placed on the long fader for detailed editing. It would need to include an obvious means of identifying which channels do, and do not, actually have that parameter in use.
Faders in Sends? D3lta 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 02-15-2018 12:25 PM
Snapshot for sends on faders? KrisHeinold VENUE Live Sound Systems 4 02-17-2014 09:34 PM
Sends on faders ThomasPMusic VENUE Live Sound Systems 5 01-05-2008 07:31 PM
faders in sends meekmonk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-06-2006 08:26 PM
How to get mini faders for sends Carl Fuehrer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-18-2005 07:24 PM
