Old 03-28-2013, 06:48 AM
crizdee's Avatar
crizdee crizdee is online now
Default Any suggestion? control 24 meters dead in PT work in Vegas mode
Ive just sold a control 24. was all working perfect when i demo'd it to the person who collected it.
Now they say the meters are not working when running sessions. but all is working fine in vegas test mode
Ive been through everything i can think of to check, pre fader, post fader, input level check, reset the control 24. different ethernet cable and so on.
but all i can think now is a connector has come off during transit! I doubt anything component wise would fail during transport.
I think they are using LE but not totally sure yet.
anything i could have missed?
any idea which cable/connector might be the problem.
UPDATE! Seems the buyer has a 003 control surface as an interface which is causing the problem!
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 03-28-2013, 03:29 PM
Delta Music Belgium's Avatar
Delta Music Belgium Delta Music Belgium is offline
Default Re: Any suggestion? control 24 meters dead in PT work in Vegas mode
I do not have a Control 24 but I do have a ProControl. With a ProControl comes a special loopback Ethernet connector, you can use this to test the build-in Ethernet connector, there are test routines for that in the Utility pages. Maybe you can do the same with a Control 24? Do you remember having such a loopback Ethernet connector?
Some other things to check:
- does Pro Tools recognise the Control 24 and is it selectable in the Ethernet window?
- is there an Ethernet hub involved and are they using the correct cables (only patch cables, no crossover cables)?
All the communication between PT and Control 24 happens by Ethernet, so it must be an Ethernet problem. I doubt very much that an internal connector has come off during transport, because Vegas Mode also needs a perfect working machine. If the meters work in Vegas Mode, all the internal print connectors are fine. Maybe the Ethernet port on the Mac/PC is broken?
Marc Schellekens
Delta Music Belgium - Pro Tools | HDX Studio
http://www.deltamusic.be
System 1: Mac Pro (Mid 2012) 3.33 GHz 6-core - 32 GB RAM - OS X 10.13.6 - Magma EB7 - PT HDX3 - PT Ultimate 2018.12 - HD I/O 16x16 - 192 I/O - 192D I/O (x3) - SYNC HD I/O - Apogee Big Ben - Rosetta 200 - Slate RAVEN MTi2 (x3)
System 2: Mac Pro (Mid 2010) 3.33 GHz 6-core - 32 GB RAM - OS X 10.9.5 - Magma PE6R4-I - PT HD 6 Accel PCI - PT HD 10.3.10 - 192D I/O - SYNC I/O
Control 24 faders not moving in vegas mode? please help primomusic ProControl, Control|24, Command|8 14 11-05-2013 09:02 PM
Vegas Mode please Craig F System 5 5 05-17-2010 01:44 PM
vegas mode stopped working on D-Control tomcat ICON & C|24 3 11-01-2007 11:15 PM
WTF is Vegas Mode ?? Bob Legs ICON & C|24 5 01-20-2007 07:19 AM
WTF is Vegas Mode ?? Bob Legs Pro Tools TDM Systems (Mac) 10 12-08-2006 10:49 AM
