Old 01-10-2009, 06:21 PM
akmusic akmusic is offline
Default Digidesign Expansion HD Chassis and PT8 help!!!!!
Anyone using this with PT8? I keep getting a weird DAE error 12001 and 12509 when trying to launch protools. I'm going crazy here quadruple checked all of the connections for my audio interfaces and everything is correct. Can anyone help?
Old 01-10-2009, 06:33 PM
Default Re: Digidesign Expansion HD Chassis and PT8 help!!!!!
Working fine here with a PCIe card and Mac Pro
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 01-10-2009, 06:36 PM
My cards are all PCi...connected to a PCIe host card, yesterday digi said it should work. The error message happens after a few seconds of trying to launch PT8, then I get a DAE error 12001.
Old 01-10-2009, 06:39 PM
Unplug the cable and start up Pro Tools... what happens?
Did you do a clean uninstall of 7.4 ?
Rail
Platinum Samples
Rail Jon, Any chance you could walk me through your setup?
Old 01-10-2009, 06:41 PM
Not sure what you're asking.. we have a stock older Mac Pro running 10.5.6 and PT8
The error you're reporting is discussed in this thread - it's not PT8 specific:
http://duc.digidesign.com/showthread...ighlight=12001
Rail
Platinum Samples
Old 01-10-2009, 06:42 PM
I never had PT in the computer at all. I unplugged the Chassis from the MAcpro, and after launching protools I got a message that said "Could not find Expansion Chassis power it up and hit retry" SO I did that and then same error. I just bought this computer yesterday. 8 core, 2.8mghz, 6gb ram
4 internal apple drives. There was nothing on this machine its completely clean. I uninstalled PT8 and then reinstalled same issue. Thanks in advance for your help.
Old 01-10-2009, 06:44 PM
Read the thread I linked you to - you need to swap out the cards.
Rail
Platinum Samples
Old 01-10-2009, 06:50 PM
Thanks for the post. Your using 10.5.6? I'm using 10.5.5. Should I just start taking out the cards one at a time to see whats causing the issue? They all worked before when they were in the G5. Also I forgot to say that I ran digitest and it had errors for every slot. IS this typical even if its only one card thats off?
Old 01-10-2009, 06:52 PM
When you say "swap the cards" do you mean change their positions in the chassis or take them out completely? For instance swap
accel card in slot 3 with accel card in position 6.
Digidesign Expansion Chassis Philee Digidesign Hardware & Software 10 10-06-2010 11:15 AM
Anyone using the Digidesign Expansion|HD chassis? MDog Pro Tools TDM Systems (Mac) 14 03-19-2007 08:58 PM
Digidesign Expansion Chassis Problems Fred Cannons Pro Tools TDM Systems (Mac) 6 12-29-2006 09:19 AM
Digidesign Expansion|HD Expansion Chassis work ok? Will Russell Pro Tools TDM Systems (Mac) 8 05-25-2006 02:19 PM
