Old 03-18-2007, 11:18 AM
MDog MDog is offline
Default Anyone using the Digidesign Expansion|HD chassis?
I'm thinking of getting a Mac Pro Quad and an exansion chassis for my PCI-X cards. I came across the following blurb though, and was wondering if anyone could tell me how bad the latency is in actual practice? I'm not using too many RTAS instruments, but use Amplitube and SVX on a regular basis. If the latency is 256 or below it could be workable for me.
Thanks!
"Systems using the Digidesign Expansion|HD chassis will incur slightly increased RTASฎ real-time monitoring latency compared with systems in which HD cards are installed in the host computer. This monitoring latency will be most noticeable when playing RTAS instrument plug-ins in real time."
My best friend is a pitbull.
http://www.badrap.org
Old 03-18-2007, 12:03 PM
minister's Avatar
minister minister is online now
Default Re: Anyone using the Digidesign Expansion|HD chassis?
hi.
i use one on a PPC. there is some increased latency with RTAS. sometimes, i use a LOT of RTAS instruments. what i do is go down to 256 or 128 for recording, and then switch to 512.
once i got some kinks worked out, and once Digi got the kinks worked out with 7.2 and Exp Chassis, 7.3.1 has been stable for me for about 2 months now with 7 day a week heavy use. again, i am on a PPC, but i think it is probably similar to the ProQuad.
hope that helps.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 03-18-2007, 05:05 PM
rupert47 rupert47 is offline
Hi
This set up has worked well for me, other than the fan in the expansion chassis being a little loud. I use rtas instruments every now and then, for me the latency is very acceptable when set to 256.
Randy
Mac Pro 3ghz
Protools 7.3.1cs2
Hd3 accell
Old 03-18-2007, 05:12 PM
I replaced the CPU fan in my chassis and it's MUCH quieter.
The chassis RTAS latency is twice that of the latency when no chassis is used.. so a setting of 128 with the chassis is equivalent to a setting of 256 without the chassis.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 03-18-2007, 10:25 PM
K.I. K.I. is offline
Hi.
I use it, too, but a problem happens in Altiverb well. It was PCI, but the problem had nothing before.
However, the aspect of setting improved because a cable with Mac became long.
Old 03-18-2007, 10:40 PM
minister's Avatar
Hi.
was it Altiverb 6 TDM?
if so, there is a fix specifically for this.
Tom Hambleton CAS
IMDb
-Starcrash
Old 03-19-2007, 12:21 AM
Vaphoron Vaphoron is offline
Rail
Could you tell me what fan you used and how easy it is to replace? I am seriously considering a Mac Pro when they are updated next and that means I'm gonna need the Expansion HD.
- Jason
Old 03-19-2007, 12:24 AM
Zalman CPU fan:
Previous thread
Getting the original out was a little tricky but not too difficult.
It will void your warranty though.
Cheers,
Rail
Platinum Samples
Old 03-19-2007, 01:39 PM
roberts roberts is offline
Is the RTAS latency higher using a Magma 64 Bit chassis as well. Or is only higher on the newer Expansion Chassis HD?
Old 03-19-2007, 01:57 PM
It's only on the Expansion/HD because it's a "smart chassis".
Rail
Platinum Samples
Digidesign Expansion Chassis Philee Digidesign Hardware & Software 10 10-06-2010 11:15 AM
Digidesign Expansion HD Chassis and PT8 help!!!!! akmusic Pro Tools TDM Systems (Mac) 10 01-10-2009 07:28 PM
Digidesign Expansion Chassis Problems Fred Cannons Pro Tools TDM Systems (Mac) 6 12-29-2006 09:19 AM
Digidesign Expansion|HD Expansion Chassis work ok? Will Russell Pro Tools TDM Systems (Mac) 8 05-25-2006 02:19 PM
